dbbmwm3 Posted August 21, 2010 Share Posted August 21, 2010 (edited) 16' open trailer with full steel deck and electric brakes on all four wheels that also includes: • Atwood power jack, which makes life so much more convenient than turning the manual jack handle • Husky aluminum tongue box that's big enough to hold fluids, jack, 4 jack stands, nitrogen bottle and lots of tools. Lock & keys included. • Trailex aluminum tire rack that holds 8 245/40R17 tires. Padlock with keys included. • Spare trailer tire mounted on the tire rack • Wood ramps that you put under the steel ramps to help load a lowered car Basically, this is a fully loaded, ready to go race/track car trailer with all the goodies you'd need. The front of the trailer also has room for five 5 gallon fuel jugs, but the aluminum fuel boxes would not be included. Here's the manufacturer's description of the trailer (w/o the options I later installed): • GVWR: 7,000 lb. GVWR • Axles: (2) 3,500 lb. Axles with Electric Brakes -Easy to Lubricate Hubs • Brakes: Electric Brakes on Both Axles (All 4 Wheels) – DOT Requirement in Most States • Frame: 5” Channel Frame with 5” Channel Wrap Around Tongue -Stake Pockets Down Both Sides of Trailer -4 “D” Rings on Floor of Trailer -Headache Bar (Front Rail) • Deck: 1/8” Diamond Treadplate Deck -82” Between the Fenders – Overall Width 102” -2’ Dove Tail (drops approximately 2”) • Cross Members: 2” x 3” Angle on 24” Centers • Fenders: Heavy Duty Treadplate Fenders with Center Knee Brace -Fender Flares with LED Lights Front & Rear • Tires: 15” “C” Range Trailer Tires - 5 Lug - (ST205/75D15) • Jack: 2,000 lb. Jack -Set Back Jack • Lights (Everywhere) & Safety Equipment: -Tail Lights with Steel Guards - Mounted in Vibration Dampening Material -LED 3-Light Bar in Rear Center -Side Marker Lights -7 pin RV Plug with Sealed Lighting Harness -D.O.T. Reflective Tape -Safety Break-Away Kit with Battery (Self-Charging) -Safety Chains • Coupler: 2 5/16” Hitch Ball Receiver with Spring Lock -Tongue Height at Ball Coupler: Approximately 15” (level trailer) • Ramps: Adjustable Treadplate Covered 5’ Rear Slide In Ramps With Latches • Paint: Primed & Painted Black, Top and Bottom As you see from the pictures, the trailer is and always has been stored in my garage. The trailer is located in Raleigh and is ready to go. SOLD Edited August 26, 2010 by Guest Quote Link to comment Share on other sites More sharing options...
Jazzy Posted August 23, 2010 Share Posted August 23, 2010 If you would let me know your "taking" price. Thanks, Sam Adams [email protected] Quote Link to comment Share on other sites More sharing options...
dbbmwm3 Posted August 23, 2010 Author Share Posted August 23, 2010 If you would let me know your "taking" price. Thanks, Sam Adams [email protected] You have email. Quote Link to comment Share on other sites More sharing options...
D_Eclipse9916 Posted August 25, 2010 Share Posted August 25, 2010 If you would let me know your "taking" price. Thanks, Sam Adams [email protected] You have email. Same, ill be rolling through on my way down to Myrtle this weekend, Fitzpadj AT gmail.com Quote Link to comment Share on other sites More sharing options...
dbbmwm3 Posted August 26, 2010 Author Share Posted August 26, 2010 Trailer has been SOLD Quote Link to comment Share on other sites More sharing options...
