asifnyc 0 Posted December 6, 2010 Author Share Posted December 6, 2010 thanks guys, appreciate the answers. Quote Link to post Share on other sites
Renesisfury 0 Posted December 9, 2010 Share Posted December 9, 2010 That is one badass yellow AMX. Quote Link to post Share on other sites
asifnyc 0 Posted December 9, 2010 Author Share Posted December 9, 2010 That is one badass yellow AMX. thanks! if you like the yellow Javelin just wait till the race car is done Quote Link to post Share on other sites
bulletpruf 0 Posted December 9, 2010 Share Posted December 9, 2010 Asif - Did I see on your blog that you had decided on an engine? If so, care to share any info? You're not putting a shivverlay in it, are you?!?! Scott Quote Link to post Share on other sites
asifnyc 0 Posted December 10, 2010 Author Share Posted December 10, 2010 speed-o-motive in west covina, ca is doing the engine. in 2012 american iron rules say engine make and car make must match. so I'm building an AMC 360. should be done about the end of january. Quote Link to post Share on other sites
bulletpruf 0 Posted December 10, 2010 Share Posted December 10, 2010 speed-o-motive in west covina, ca is doing the engine. in 2012 american iron rules say engine make and car make must match. so I'm building an AMC 360. should be done about the end of january. Sounds like a good AI build - 360's are easy to find, inexpensive, and can make your hp goal w/o any problem. Scott Quote Link to post Share on other sites
asifnyc 0 Posted December 11, 2010 Author Share Posted December 11, 2010 hey guys, do any of you run a pump and cooler for your rear-end? someone suggested I need one, do I? Quote Link to post Share on other sites
nape 0 Posted December 13, 2010 Share Posted December 13, 2010 hey guys, do any of you run a pump and cooler for your rear-end? someone suggested I need one, do I? Only if you run an IRS. Stick axles have enough fluid capacity and surface area for cooling. Quote Link to post Share on other sites
asifnyc 0 Posted December 13, 2010 Author Share Posted December 13, 2010 great thanks! Quote Link to post Share on other sites
asifnyc 0 Posted December 13, 2010 Author Share Posted December 13, 2010 today's question, I need motor mounts. my choices are: 1) Solid motor mounts 2) poly urethane motor mounts which should I run? Quote Link to post Share on other sites
Cobra4B 0 Posted December 13, 2010 Share Posted December 13, 2010 I'd run poly.... a little compliance is nice to have. I replaced the stockers in my Corvette with urethane units from Pfadt. When prepping a 120k mile car I didn't want to take the chance that one of the mounts would be torn. Plus I already had all the stuff out of the way to make for an easy install. Quote Link to post Share on other sites
asifnyc 0 Posted December 14, 2010 Author Share Posted December 14, 2010 thanks again! Quote Link to post Share on other sites
asifnyc 0 Posted December 18, 2010 Author Share Posted December 18, 2010 progress update... the engine build is in full swing. should be done around mid-january. I finished fab'ing an aluminum dash. I've ordered and received a bunch of parts (battery, radiator, steering wheel, window net, brake bias adjuster... here's a pic of the dash I made. more update info here: http://asifnyc.com/?p=807 and here: http://asifnyc.com/?p=821 Quote Link to post Share on other sites
AJ Hartman 0 Posted December 19, 2010 Share Posted December 19, 2010 looks good. it amazing what you can accomplish at home with some aluminum and pop rivets. Quote Link to post Share on other sites
Aaron B 0 Posted December 19, 2010 Share Posted December 19, 2010 Great Job on that dash - looking forward to seeing that Hot Rod in 2011 Quote Link to post Share on other sites
bulletpruf 0 Posted December 21, 2010 Share Posted December 21, 2010 Good progress! Dropped off my car at Piper Motorsports yesterday - local shop with a great reputation. Getting the cage installed, seats and harnesses mounted, etc. Guess I need to start my own Javelin build thread. I've got dash envy. I'm ditching my stocker and going with something fabricated, too. Will check out your blog for more info. Some great posts on corner carvers about wiring, too - try http://www.corner-carvers.com/forums/showthread.php?t=34419 I'm assuming your cage 1.75 x .120, but looks like some of it is smaller - is that 1.5 x .120? Looks like I'm going with 1.75 x .120 for most of my cage; AI requires that for 3,000 - 4,000 pounds (without fuel or driver). Figure I may be close to that. What are you going to do about your rear quarter windows? Couldn't see from the pictures. Are you getting rid of the window regulators, etc, and bolting the windows shut? If so, how did you do that? Also, what brand/model did you use for steering column and pedals? Thanks! Scott Quote Link to post Share on other sites
asifnyc 0 Posted December 22, 2010 Author Share Posted December 22, 2010 Scott, please start a build thread. I want to see how your car comes along. take as many pictures and as much video as you can! btw, if you like the dash I might be able to mail you the templates or even cut the pieces out of aluminum and send you the 2 flat aluminum pieces. then you would just need to put the bends in it. thanks for the wiring thread. it looks really useful. yes, cage is 1.75 x .120. the corner supports are smaller but I don't know exact size. everything related to the rear qtr windows has been removed. including the inner stamped panel that the interior side panel screws to. that stamped piece is simply bolted in place (about 6 bolts). the steering column is from speedway motors and the pedal assembly is from wilwood (purchased from summit racing). Quote Link to post Share on other sites
bulletpruf 0 Posted December 23, 2010 Share Posted December 23, 2010 Scott, please start a build thread. I want to see how your car comes along. take as many pictures and as much video as you can! btw, if you like the dash I might be able to mail you the templates or even cut the pieces out of aluminum and send you the 2 flat aluminum pieces. then you would just need to put the bends in it. thanks for the wiring thread. it looks really useful. yes, cage is 1.75 x .120. the corner supports are smaller but I don't know exact size. everything related to the rear qtr windows has been removed. including the inner stamped panel that the interior side panel screws to. that stamped piece is simply bolted in place (about 6 bolts). the steering column is from speedway motors and the pedal assembly is from wilwood (purchased from summit racing). As always, thanks for the info. Would be great if you could save your templates for the dash. Please post up some pics when you have it installed. I've removed all the quarter window hardware from my car as well. Looks like the rules would allow use of Lexan here, but I've asked the shop that's doing the cage to see if they can fix the factory windows in place without any of the factory hardware. I can cover the void with some aluminum. Think next stage of my build will be dash bar (leaving it out for now), pedals, steering column, blower motor (something from Speedway), and dash. In the meantime, I plan to re-assemble the 401 and install it and the T-10. Thanks, Scott Quote Link to post Share on other sites
asifnyc 0 Posted December 24, 2010 Author Share Posted December 24, 2010 finally got the car ready for interior paint. Going light gray. Hope to take it to the painter next week. here's the pic of the battery "box" that Jim (a fabricator I was able to get to help with a bunch of welding) made for me. More info here: http://asifnyc.com/?p=839 Quote Link to post Share on other sites
asifnyc 0 Posted January 9, 2011 Author Share Posted January 9, 2011 chassis paint... check mark. picked up the car today. insides are all painted. now I have to start putting the car back together and putting parts in/on it! received the lexan windshield I ordered a month ago and the engine is due to be completed the end of January. the fiberglass hood and front spoiler are due to arrive late next week. chances of making the first race are pretty slim at this point... but I'm going to keep at it and see what happens. other odds and ends... I bought a used ford 9" center section on craigslight. it's a posi with 3.25 gears. unfortunately I think the clutches are shot... don't know if I'm just going to try to replace the clutches or just use it for the carrier and put in a proper diff like a true trac or DPI... here's a pic of the painted cage. there's more info and a little time lapse video of me welding/grinding trim holes at: http://asifnyc.com Quote Link to post Share on other sites
svttim 0 Posted January 9, 2011 Share Posted January 9, 2011 Car is looking good.Cant wait to see the end result Quote Link to post Share on other sites
asifnyc 0 Posted January 9, 2011 Author Share Posted January 9, 2011 thanks! anyone got any recommendations on what mufflers to run? Quote Link to post Share on other sites
supermac 0 Posted January 9, 2011 Share Posted January 9, 2011 thanks! anyone got any recommendations on what mufflers to run? Boom Tubes Rock! Quote Link to post Share on other sites
asifnyc 0 Posted January 10, 2011 Author Share Posted January 10, 2011 boom tubes - who makes them? where do I get them? thanks! Quote Link to post Share on other sites
firehawkclone 0 Posted January 10, 2011 Share Posted January 10, 2011 boom tubes - who makes them? where do I get them? thanks! http://drgas.com/ Big $$$$ look for used stuff! Car is looking good, to bad i wont get to run with you this year! Quote Link to post Share on other sites
