clydesdale Posted September 7, 2010 Posted September 7, 2010 If I have negative modification points is it allowable to move down a class from the base class? It might be useful to point out whether or not this is allowed in the rules -- at least for clarity (or did I just miss it?). Quote
National Staff Greg G. Posted September 7, 2010 National Staff Posted September 7, 2010 It is permitted, and rarely happens. You must still be compliant with the limit on Adjusted Wt/Hp ratio for that class. Since the only credit points are for tire size, it means that you are running on smaller tires, probably street tires, and have little or no mods to the vehicle otherwise. Quote
kbrew8991 Posted September 9, 2010 Posted September 9, 2010 see also - TTF at NASA Nationals 2008 with a '99 Miata that's really the only time I've seen or heard of it happening. Quote
