whaden Posted May 24, 2011 Share Posted May 24, 2011 Excellent write up...thank you. Quote Link to comment Share on other sites More sharing options...
dbgeek Posted May 24, 2011 Author Share Posted May 24, 2011 I'm too slow to understand what you are saying but what corrected me after I was off on timing, was to turn the VANOS wheel back a tad so that it caught the first tooth. The first time it was probably just enough to skip the first and get the second, therefore not good (and in accordance with the Bentley). Maybe I'm saying the same as you, but mine showed up on timing, and it sounds like you are saying it wouldn't. When I seriously blow my head to pieces I'll have a model to play with I think we're saying the same thing. I think your 'vanos wheel' is what I'm calling the gear cup. If you are on the correct internal spline, it goes right in. If you are on the 'odd' spline (one over from correct) you 'skip the first and get the second'. and yes, it would show up once you rotate the engine a couple turns (the step i didn't know about, as Beisan doesn't mention it) Quote Link to comment Share on other sites More sharing options...
Members Jon M. Posted May 24, 2011 Members Share Posted May 24, 2011 you people are 1. too smart and 2. making my head hurt. Quote Link to comment Share on other sites More sharing options...
dbgeek Posted May 24, 2011 Author Share Posted May 24, 2011 you people are 1. too smart and 2. making my head hurt. You so crazy! I take picture, make it all better. except this forum doesn't host... hmmmm Quote Link to comment Share on other sites More sharing options...
dbgeek Posted June 20, 2011 Author Share Posted June 20, 2011 For those who are interested, here is a picture of the cam blocks when the VANOS is installed 'off a tooth': Quote Link to comment Share on other sites More sharing options...
Scany Posted June 20, 2011 Share Posted June 20, 2011 For those who are interested, here is a picture of the cam blocks when the VANOS is installed 'off a tooth': Yeah, that's just like I had it installed when I did it wrong. I find it hard to believe this is "better", but only one way to find out Quote Link to comment Share on other sites More sharing options...
Members Jon M. Posted June 20, 2011 Members Share Posted June 20, 2011 I arranged the last dyno tuning process. It is someone elses turn. Quote Link to comment Share on other sites More sharing options...
dbgeek Posted June 20, 2011 Author Share Posted June 20, 2011 Would it be legal? The old "if it doesn't say you can, then you can't" Quote Link to comment Share on other sites More sharing options...
Members Jon M. Posted June 20, 2011 Members Share Posted June 20, 2011 depends on manufacturer specs Quote Link to comment Share on other sites More sharing options...
Scany Posted June 20, 2011 Share Posted June 20, 2011 I will stay factory untill a guy with the VANOS adjustment pulls on me I'm trusting the BMW engineers on this one. Quote Link to comment Share on other sites More sharing options...
Members Jon M. Posted June 20, 2011 Members Share Posted June 20, 2011 I will stay factory untill a guy with the VANOS adjustment pulls on me Someone needs to check Mike's VANOS settings then. Quote Link to comment Share on other sites More sharing options...
Scany Posted June 20, 2011 Share Posted June 20, 2011 Someone needs to check Mike's VANOS settings then. you need to take the turn properly before you talk like that Quote Link to comment Share on other sites More sharing options...
dbgeek Posted June 21, 2011 Author Share Posted June 21, 2011 I arranged the last dyno tuning process. It is someone elses turn. There is a dyno about 20 minutes from here (BW was a 3-4 hour tow). I can do 3 runs each with the stock chip and the BW chip. Then I can change the Vanos and do 3 runs with each chip again. It will cost $200-300 and a day of time. BUT... clearly this isn't allowed in the rules, so should we? Quote Link to comment Share on other sites More sharing options...
Members Jon M. Posted June 21, 2011 Members Share Posted June 21, 2011 The only value add to doing it would be to have the data so that it is easy to verify someone who is not playing by the rules. Quote Link to comment Share on other sites More sharing options...
Scany Posted June 21, 2011 Share Posted June 21, 2011 The only value add to doing it would be to have the data so that it is easy to verify someone who is not playing by the rules. Protest and take the valvecover off and verify intake cam location. Almost easier and cheaper than setting up a dyno which could be inconclusive anyway. Should you have to pay for the work it's only a valvecover gasket and 1-2 hours of labor. That said, a failure in the VANOS I imagine could lead to a situation that would be illegal in this respect, but caused by a failed part, and not an intentional cheater. Then the VANOS system needs to be tested for proper operation, which is slightly more involving. Why would someone not play by the rules? Quote Link to comment Share on other sites More sharing options...
Members Jon M. Posted June 21, 2011 Members Share Posted June 21, 2011 Protest and take the valvecover off and verify intake cam location. As history has shown, we use the dyno to verify legality as part of the impound process. Thankfully, NASA provides this to us for free as a way to quickly check for outliers. The greater the comparison data we have to use when impound dyno runs are performed, the smarter we can be at catching outliers. Very few racers tend to put up the cash to protest a competitor's engine. Alternatively, expressing concerns over a competitor's power levels (video evidence is often the best way to support those concerns) can aid officials when determining the dyno impound individuals. Quote Link to comment Share on other sites More sharing options...
dbgeek Posted June 21, 2011 Author Share Posted June 21, 2011 My valvecover gasket doesn't stick - I use Hylomar as the sealing goop, and re-use the gasket the 3 times the cover has been off. Perhaps we can have a friday night ritual of removing all our valvecovers. I'll show you mine if you show me yours? Quote Link to comment Share on other sites More sharing options...
whaden Posted June 21, 2011 Share Posted June 21, 2011 Perhaps we can have a friday night ritual of removing all our valvecovers. I'll show you mine if you show me yours? Quote Link to comment Share on other sites More sharing options...
MDizzle Posted June 22, 2011 Share Posted June 22, 2011 I will stay factory untill a guy with the VANOS adjustment pulls on me Someone needs to check Mike's VANOS settings then. You can check it when the engine goes, I'm scared to even touch the damn engine, it runs so well inspite of the high mileage it has. I want to open it up and do the oil pump nut / rod bearings / oil pan baffle for longevity, but i'm scared i might mess up something that already works. don't touch it if it don't need fixin right?...or something along those lines. I got some damn good video this wkd btw, just need to upload it.... Quote Link to comment Share on other sites More sharing options...
Members Jon M. Posted June 22, 2011 Members Share Posted June 22, 2011 I got some damn good video this wkd btw, just need to upload it.... Looking forward to seeing the video from Saturday. Quote Link to comment Share on other sites More sharing options...
