Now only $3.5K '88 Honda CRX Si NASA/SCCA ITA/EMRA Prepared.
1988 Honda CRX Si - ITA/NASA ST4/EMRA Prepared . Turnkey race car set up & ready to race. Easy to take to track (I use a tow dolly that is easy to store)
I had this at $7000. Would $3,500 make it more interesting to anyone?
Pictures
http://picasaweb.google.com/101983910157367538905/CRX?authkey=Gv1sRgCMrYyN7Nn43czQE#
Engine
• IT prepped Head (Shaved .015", valve job, new valve guides, seals, gasket matched intake/exhaust ports, 1990 camshaft)
• Stock shortblock (190-198 compression in cylinders, 3-6% leakdown tested)
• Gasket matched intake manifold
• New headgasket, water pump, timing belt, cap/rotor, alternator belt, intake/exhaust/throttle body gaskets, valve cover gasket, cam seal, injector o-rings, upper/lower radiator hoses, throttle cable, spark plugs, spark plug wires, battery.
• DC Sports 4-2-1 header
• New 2.5" exhaust with new Dynomax resonator, turndown
• AEM intake w/ K&N filter (rain and cold air setups)
• Balanced/blueprinted injectors
• New B&M Fuel pressure regulator with new gauge
• Custom catch tank for crank case breather
• 1990 OE ECU, socketed with 3 available chip programs (stock, Mugen, RPT programs)
• Dyno tested at 121hp/113tq in 3 baseline runs on stock ECU program.
Transmission
• 5 Speed Manual. Shifts smoothly with no grinds
• New OPM LSD
• New ATS 4.73:1 final drive
• New Exedy clutch disc, new OEM pressure plate, throw, release bearing
• New remanufactured flywheel
• New Axle, other is still good.
• Honda MTF fluid
Suspension/Wheels/Tires
• New Koni single adjustable shocks (all 4 revalved, shortened front units)
• Ground Control coilovers
• New pairs of 500lbs, 650lbs and 750lbs springs (car currently has 500/650's on)
• New Mugen rear trailing arm bushings
• New radius rod bearings
• New Prothane master bushing kit
• Suspension Techniques 22mm adjustable rear sway bar
• Generic front strut bar
• 89-91 rear LCA's
• 14x7 Panasport wheels
• 205/55/14 Toyo RA-1's
• Also have stock CRX wheels with tires for wet racing.
Brakes
• New front/ rear rotors
• Drilled & Grooved Front & Rear rotors – good shape and stop like a mofo.
• New front calipers
• New Hawk Blue front & Rear pads
• New OEM replacement rear pads
• New 90/91 CRX Si master cylinder
• New brake booster
• Motul 600 fluid
Interior
• Momo Nascar seat
• Momo seat rails
• New G-Force Cam-lock 5 point harness
• Momo Top Power steering wheel
• New quick release from LTB Motorsports for steering wheel (brings wheel 2.5" closer to driver)
• New Sparco window net
• New M&R window net hardware
• New in-dash gauge panel (new Autometer Phantom Series 3 3/8" tach, 2 1/16" water temp gauge, 2 1/16" oil pressure gauge)
• New Moroso starter/ ignition and accessories switch panel
• Skunk2 shift knob
• Generic pedal covers
• 2.5lb fire extinguisher
• Sound dampening removed
• 8 point welded cage (fabricated by S-Car-Go Racing)
• Recent interior paint (black cage, grey interior)
Exterior
• Recent Paint ( single stage, Championship White)
• Sparco hood pins
• Riveted sunroof panel
Misc.
• To be SCCA/NASA legal, the car still needs a fuel test port (Should be < $20).
• Car was set up, balanced & corner weighted by RedShift motorsports. Feels great
• Weighs just shy of 2,000 LB. This is light and the car has always run in the top percentile of its group on the tracks I’ve been on (Pocono N/E/S, NJMP etc.)
• Spare D16A6 Engine also included and ready to go on an engine stand.
Pictures
More avail if you want them.
The Deal
Looking for offers in the $7,000 range (might consider a trade for a 2-seater street car). Reluctant sale but 3 kids and a recent house & job change are not leaving me any time to spend on my favorite hobby right now. Photos avail for interested parties. Doylestown PA area. Can deliver within 100 miles.
  • 4 months later...
