Griggs Racing Aluminum Drop Spindle Kit
Boss302R
I have a new set of spindles, hats, brake brackets and rotors from Griggs Racing. All parts are new, asking $2,000 plus shipping for everything. If you need pics, please e-mail. Description of parts is from the Griggs site.
Several new features never offered in a spindle before are incorporated in the design, and patents are pending. Using a large, serviceable Timken double roller bearing, the entire assembly is lighter and far more rigid than an OEM SN95 or SN197 spindle/hub assembly, improving brake performance, cornering power and steering accuracy. Test results indicate 4 to 5 times stronger than OEM spindles and hubs.
2" drop and overall design allows use on SLA systems with upper ball joint inside wheel, allowing wider front tires.
Current configurations fit all GR350 & GR40 SLA Mustangs, Factory 5 Cobras and similar applications
Currently available with 8.7 degree KPA and 10 inch length upper and lower ball joint design, and soon to fit late model Mustang strut systems, the modular design of the spindle accommodates many different configurations and vehicle usage as well as ease of repair. Talk to us about your needs.
The included hat is integral with the hub to retain the Bearing. Also available are stainless steel brake brackets, hats and floating rotors for Griggs Racing Brakes and other popular brands. Each component of every assembly is beautifully clear anodized for corrosion resistance, and serialized to assist time management for servicing assemblies used on race vehicles.
