FS/FT: 92 Spec Miata, race ready and car trailer available
jerseybrandon
Current SCCA and NASA logbooks, nice cage with nascar bars on both sides, fuel test port, huge rearview mirror, removable steering wheel, tow hooks, window net, AMB transponder, fire extinguisher, Kirkey aluminum seat w/cover and head restraint, 6 point harness, master battery disconnect switch, taylor wires, NGK plugs, SS brake and clutch lines, ACT 4 puck, stock pressure plate (when the clutch was done a new rear main seal, throw out bearing, pilot bearing and slave cylinder also went in along with a fresher trans which shifts flawlessly, the old trans is also included), redline fluids through out, new fuel filter, race exhaust (looks like springfield dyno but not 100% sure), Republic or SP intake w/K&N, Spec Miata suspension kit (obviously), Carbotech pads (and spare used Carbotechs) with new rotors all around, ATE blue fluid, blueprinted front hubs w/ARP long studs, 3 sets of wheels and tires: one set of oem 14's with junky street tires for storing, one set of new TD's w/shaved RA1's (only 2 heat cycles), one set of not new but great condition TD's w/full depth sticker RA1's, professionally aligned and weighed to Jim Daniels spec. The paint is not showroom pretty as you would expect, the car is black, as are the wheels. Overall the car is in good shape, no rust, no major hits, runs great and is ready to race.
Anything in bold is new, meaning 1 event or less.
Please email more for more info and photos. The price is $7500. Located in NJ. Open car trailer with tire rack, aluminum tool box, electric winch and a vise is also available for $2000.
Thanks for looking,
Brandon
  • 2 weeks later...
  • 3 weeks later...
