FS: GTS2/JP E46 330Ci Race Car
Posted (edited)
Sold.
This car started out as a 2001 330Ci which I bought CPO in late 2003. I turned it into a race car in early 2008 and it has been raced 9 weekends since. It has finished every weekend with almost no issues whatsoever, overall it’s been extremely reliable. Motor and Chassis currently have 78,631 miles. This car last dynoed 219.23 WHP and 218.31 WTRQ. The GTS2 minimum weight is 3179 lbs and the JP minimum weight is 3154lbs (ballast plates on the passenger side floor are easily changeable).
Asking $25,000.
Engine/Drivetrain:
Technik Engineering Generation 3 Headers
Modified OEM 4 Bolt Oil Pump
Victory Product Design Oil Cooler
VAC Oil Pan Baffle
Jim Conforti Intake
Stewart Water Pump
Vorshlag Polyurethane Motor Mounts
UUC Polyurethane Race Trans Mounts
UUC Aluminum Flywheel and Sachs Power Clutch
Rogue Engineering Octane SSK
Jaffster Shift Knob
Turner Motorsport 3.46 LSD
Z4 Finned Diff Cover
Turner Motorsport Aluminum Subframe Bushings
Turner Motorsport Aluminum Differential Bushings
BimmerWorld Wheel Studs
Suspension:
JRZ RS/BimmerWorld Dampers
Ground Control Camber Plates
Ground Control Spherical Rear Shock Mounts
Ground Control Rear Weight Jackers
Ground Control Spherical Rear Lower Control Arms
Ground Control Front Sway Bar Endlinks
UUC Sway Barbarians
Eibach Springs(800/1000)
Mason Engineering Strut Bar
TC Kline Delrin Front Control Arm Bushings
PowerFlex Polyurethane Rear Trailing Arm Bushings
BMW OEM Strut Tower Reinforcement Plates
Brakes:
UUC Stainless Steel Brake Lines
Performance Friction 06/01 Pads
Front Brass Caliper Bushings
Ducting
Interior/Safety:
Prepared Legal 6+2 Roll Cage(TIG welded)
POR 15 Painted Interior
Interior Wiring Thinned and Wrapped in Loom
Turner Motorsport Rear Subframe Mount Reinforcements
Turner Motorsport Motor Mount Reinforcements
Ground Control Rear Sway Bar Tab Reinforcements
Schroth Profi-II 6 Harness
TeamTech Window Net/BimmerWorld Mounting Kit(recently replaced)
TeamTech/BimmerWorld Right Side Net(recently replaced)
Split Shaft Collars for Harness and Center Net
Stack Oil Pressure, Oil Temp, and Water Temp Gauges
VAC Seat Base Mount
Cobra Seat Side Mount
VAC Aluminum Floor Pans
FireSense 4.0L AFFF Fire System(recently serviced)
Lots of SFI Roll Cage Padding
LongAcre 17” Convex Interior Mirror
Exterior/Aero:
MTech II Front Bumper
Sunroof Panel Filled in by Body Shop
APR Wing(Mounted), GT Racing Wing(Unmounted)
Baller Gold Alumalite Quick Release Splitter
TC Design Tow Hooks
OEM Clear Taillights
Wheels/Tires:
4 18”x9” ARC-8’s
4 17”x8.5” Kosei K1’s
4 275/35/18 Nitto NT01’s, ~12 HC(Mounted)
4 225/45/17 Hoosier Rains, 2HC(Mounted)
4 255/35/18 Hoosier R6’s, 1 HC
EDIT: The car does not come with a seat.
Feel free to email me with any questions at gregsmith717 at gmail dot com . The car is located in Fort Worth, TX.
Gallery: http://img205.imageshack.us/gal.php?g=25dscn0627.jpg
25dscn0633.th.jpg25dscn0635.th.jpg25dscn0627.th.jpg25dscn0647.th.jpg25dscn0643.th.jpg
25dscn0649.th.jpg25dscn0650.th.jpg25dscn0656.th.jpg25dscn0661.th.jpg25dscn0666.th.jpg
why are all you JP guys suddenly selling your cars?
I want to build and race something different, probably either a spec miata or spec boxster. I'd entertain a trade for either.
  • 4 months later...
