zachspeed Posted October 7, 2010 Posted October 7, 2010 (edited) NASA TTE Track/ NASAx E prepared 1993 Classic SE-R for sale No 5th gear popout. Multiple class wins, Quick and reliable CONTACT: Zach Mickle [email protected] PRICE: $3200 Clean VA title Recent Va state inspection. Pictures (these are not recent but NOTHING has changed since they were taken) http://s842.photobucket.com/albums/zz348/b13ser/?albumview=slideshow MECHANICALS: Brakes / Suspension Progress group Coilovers Ground Control Camber plates dealer purchased Ad22vf calipers Crown stainless lines Brembo OE replacement rotors Hawk Hp+ pads Motul RBF 600 fluid 15" Kosei K1 racing near perfect condition 225/45/15 Toyo ra-1 (1-2 weekends left). Set 14x7 nx wheels need tires Year old ft. LCA's with bushings and ball joints. OEM wheel bearings Extended Nismo studs in front hubs Unbalanced Enginneering bump steer kit (heim joint tie rods) INTERIOR: Gutted. white. Stock seats and door panels simplified dash with havac controls removed. No radio installed, but have old JVC cd player that I will include Kirk Racing 4 point race bar 2year old gforce camlock 5 point harness. blue. Stock belts are still installed for street driving. Drive Train: 147xxk mi original engine Oil changed after every event with synthetic mobil1 recently switched to german Castrol 0w30 DEI heat wrapped SSAC Header AEM cold air intake Engine put down a very healthy 137hp 121 tq Dynoed at Performance Autosport dynojet 248 in early August REPLACED OR RECENTLY SERVICED ITEMS timing cover/oil pump chain tensioner water pump harmonic balancer injector o-rigs tune up with All Oem Nissan parts Castrol Syntec 0w30 Redline MT90/Heavy Shockproof mix in trans. (shifts perfect) ES Mount Kit aftermarket OE replacement Axles Nx2000 dual core radiator oem ECU plus a spare JWT pressure plate oem B15 disk Fidanza 9.5 lb Flywheel alternator New Starter Straignt exhaust With Dynomax muffler 1 year old Battery No Ac still has both fans EXTERIOR: BRE INSPIRED VINYL GRAPHICS (removable) Fair to Good cosmetic condition. Previous owner had a minor bump with the front of the car. The fenders are just slightly blemished near the lamps Stillen Urethane bumper cover. Factory rear spoiler 100% Mechanically perfect. There is absolutely NO FRAME DAMAGE and the car is laser aligned perfectly. The bad: Like I said the body is not in a show quality, but cleans up nice. The exhaust rattles and is a little raspy. The hangers are soft and a resonator would help. No cat. Summit Racing sells spun core cats for less than $100 bux if you need one for compliance. Airbag has been disabled. I have nearly every receipt for what is on the car. If you have any questions please ask Adult owned and serviced. I have many pictures and can take specifics upon request. I welcome test drives and inspections. Located Richmond Va. Can be brought to VIR and Summit Point during NASA weekends $3200 obo Edited October 18, 2010 by Guest Quote
wheelpowerracing Posted October 10, 2010 Posted October 10, 2010 Good luck with your pending sale! Nice car for someone. I've seen it perform at Mid-Atlantic Auto-X's and even been given a couple rides. Quote
Red00gt Posted October 10, 2010 Posted October 10, 2010 Ya, good luck. I'm a big SER fan. Had 2 of them. If i didnt already have a track car, good chance I would have went for yours. Good looking car and they are fun to drive. Quote
Chicane Posted October 12, 2010 Posted October 12, 2010 Good luck on the sale. Unrelated question. I have an SE-R like yours -- and it has the Stillen body kit (I see that you have the Stillen front bumper cover). Did you have to take points for that to run in PTE? I cannot see any possibility of an aero advantage ... but, the rules do say you have to take points for a non OEM facia. Just checking before I buy a new bumper cover. I am going to be running in PTE here in the Mid-Atlantic region. Quote
zachspeed Posted October 18, 2010 Author Posted October 18, 2010 Good luck on the sale. Unrelated question. I have an SE-R like yours -- and it has the Stillen body kit (I see that you have the Stillen front bumper cover). Did you have to take points for that to run in PTE? I cannot see any possibility of an aero advantage ... but, the rules do say you have to take points for a non OEM facia. Just checking before I buy a new bumper cover. I am going to be running in PTE here in the Mid-Atlantic region. Thanks everyone for the kind words. I did end up selling it Sunday. It went to a good home and we will see it again on track soon. Chicane- You do have to take points, and man I agree its not an advantage. But those are the rules. Ill be sure to come by and say hello. Be on the lookout for a Red NX2000 Thats me. Quote
