FlyBoyGeo Posted October 2, 2013 Share Posted October 2, 2013 Thanks Marshall, that gives me a better idea. I like pictures Decisions decisions. Quote Link to comment Share on other sites More sharing options...
marshallmosty Posted October 2, 2013 Share Posted October 2, 2013 I originally had clearanced my calipers and have not experienced any on-track related issues over the last 7 years of track life. Some folks are nervous about grinding away material that StopTech obviously wanted to be there. Right before I did this work, there was a StopTech technician at one of our events crewing for another racer and I asked him about the mods and showed pictures from someone esle that had done the work. He indicated there was plenty of "meat" in that area of the caliper and that I won't have any issue with blowing into the internal bits. Quote Link to comment Share on other sites More sharing options...
Grizlbits Posted October 2, 2013 Share Posted October 2, 2013 I have clearanced my Stop tech in the exact same way to clear my ccw wheels. Quote Link to comment Share on other sites More sharing options...
suck fumes Posted October 4, 2013 Share Posted October 4, 2013 If you run the 18mm offset 17x9.5 you don't need to clearance at all. I have a 5mm spacer but its not needed. Quote Link to comment Share on other sites More sharing options...
99cobra2881 Posted October 4, 2013 Share Posted October 4, 2013 If you run the 18mm offset 17x9.5 you don't need to clearance at all. I have a 5mm spacer but its not needed. On which bodystyle? S197, sn95 or fox? Quote Link to comment Share on other sites More sharing options...
FlyBoyGeo Posted October 4, 2013 Share Posted October 4, 2013 I'm hoping he is talking about sn95. Great info being shared!!! Quote Link to comment Share on other sites More sharing options...
suck fumes Posted October 4, 2013 Share Posted October 4, 2013 2004 model. Sn99 which is the same as sn95 Quote Link to comment Share on other sites More sharing options...
marshallmosty Posted October 4, 2013 Share Posted October 4, 2013 Anthony, Aaron's reference is on a SN99 car. Most FOX cars use the same spindles/hubs from '94-04. Quote Link to comment Share on other sites More sharing options...
99cobra2881 Posted October 5, 2013 Share Posted October 5, 2013 Ok thanks. I'm thinking about getting a set of RPF1s and didn't want to order the 18mm offset then find out that offset was for a S197 hub!!! Quote Link to comment Share on other sites More sharing options...
suck fumes Posted October 5, 2013 Share Posted October 5, 2013 The offset for the s197 is 40-45mm Quote Link to comment Share on other sites More sharing options...
FlyBoyGeo Posted October 8, 2013 Share Posted October 8, 2013 Two sets of 17 x 9 +22 for sale in the forums. The 9" wide DO NOT fit 13" ST40 kit correct??? Only the 9.5 with mods. Quote Link to comment Share on other sites More sharing options...
suck fumes Posted October 8, 2013 Share Posted October 8, 2013 I can only speak for 17x9.5. 18mm offset. Don't know about any other sizes fitting? Quote Link to comment Share on other sites More sharing options...
jslindst Posted October 24, 2014 Share Posted October 24, 2014 The Enkei RPF1 (17x9.5) CAN be installed with StopTech ST-40 calipers. You have to clearance the caliper slightly, but I had a StopTech engineer review the modification a few years back and he said it wouldn't compromise the integrity of the caliper body. The 18mm offset (3797956518SP) will install with no spacers, but minimal caliper clearancing. The 38mm offset (3797956538SP) will install with one 1/2" spacer and minimal caliper clearancing. Bringing this one back from the dead, those of you that went with the 17x9.5 with 18mm offset on an 94-98 SN95 chassis, did you have to do any fender mods for clearance? Any info/pics is appreciated. Quote Link to comment Share on other sites More sharing options...
