SNAKBITN Posted December 16, 2010 Share Posted December 16, 2010 Joe those's rules are to protect you from your self.If that sentra goes any faster it's going to lift off the ground.Forget the steering wheel,your going to need a rudder. Robert Quote Link to comment Share on other sites More sharing options...
smokinjoe Posted December 16, 2010 Share Posted December 16, 2010 Rules are just helpful suggestions for stupid people Unfortunately, if there is no NASA rule its a violation Quote Link to comment Share on other sites More sharing options...
hired wrench Posted December 16, 2010 Share Posted December 16, 2010 the correction factor for weight took a big hit....... looks like a max of 271whp now Quote Link to comment Share on other sites More sharing options...
drivinhardz06 Posted December 16, 2010 Share Posted December 16, 2010 the correction factor for weight took a big hit....... looks like a max of 271whp now am I missing something? looks the same as last year Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted December 16, 2010 Share Posted December 16, 2010 be sure you're looking at the correct table as well, there are two sets - one for TTU/S and one for A-F Quote Link to comment Share on other sites More sharing options...
D_Eclipse9916 Posted December 16, 2010 Share Posted December 16, 2010 Loving the new ruleset, cleaned up a few things I thought should be cleaned up. Such as header wraps/coatings rule is completely clear, and although I still think cat-backs at +2 for NA cars is way too much, I need it otherwise I have to focus on the tach too much. Also I think my steering rack is going so I was bummed to see that we couldnt do ratio changes, but now we can!!! woot! Quote Link to comment Share on other sites More sharing options...
smokinjoe Posted December 16, 2010 Share Posted December 16, 2010 The cam pts are still way out of line for 4bangers. There is no parity when you get into TTC and above where the larger bore motors live. Quote Link to comment Share on other sites More sharing options...
Rob S. Posted December 16, 2010 Share Posted December 16, 2010 If the base weight of your car changed in the 2011 rules and you currently have a 2010 re-class, I would assume you would have to get a new re-class for 2011. And the 2011 re-class would result in lower whp for the same weight. Quote Link to comment Share on other sites More sharing options...
Vinny Posted December 16, 2010 Share Posted December 16, 2010 looks like the 1.8 Miatas better get busy adding some lead man sucks for those guys Quote Link to comment Share on other sites More sharing options...
smokinjoe Posted December 16, 2010 Share Posted December 16, 2010 If the base weight of your car changed in the 2011 rules and you currently have a 2010 re-class, I would assume you would have to get a new re-class for 2011. And the 2011 re-class would result in lower whp for the same weight. I would hope your reclass remains in effect as stated. Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted December 16, 2010 National Staff Share Posted December 16, 2010 If the base weight of your car changed in the 2011 rules and you currently have a 2010 re-class, I would assume you would have to get a new re-class for 2011. And the 2011 re-class would result in lower whp for the same weight. I would hope your reclass remains in effect as stated. If the base classing has changed, the re-classing will change (most likely). Either way, it must be resubmitted. Quote Link to comment Share on other sites More sharing options...
Rob S. Posted December 16, 2010 Share Posted December 16, 2010 If the base weight of your car changed in the 2011 rules and you currently have a 2010 re-class, I would assume you would have to get a new re-class for 2011. And the 2011 re-class would result in lower whp for the same weight. I would hope your reclass remains in effect as stated. If the base classing has changed, the re-classing will change (most likely). Either way, it must be resubmitted. Thanks Greg. That's what I figured. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted December 16, 2010 Share Posted December 16, 2010 Either way, it must be resubmitted. which section says that? It makes sense to have to resubmit your reclassification material if your car's listing changes, but I didn't find where it was required by the ruleset. Quote Link to comment Share on other sites More sharing options...
Markus Posted December 16, 2010 Share Posted December 16, 2010 If the base classing has changed, the re-classing will change (most likely). Either way, it must be resubmitted. That loud whooshing sound was Greg's inbox getting flooded with reclass verification requests.... Quote Link to comment Share on other sites More sharing options...
speedengineer Posted December 17, 2010 Share Posted December 17, 2010 Glad to see there weren't many large changes to the ruleset. Looks good! Lots of clarifications on specifics/phrasing, etc! Bummed to see this though - so much for using my current size star specs as backup and as rain tires... 4) DOT-approved (non-R-compound) tires with a UTQG treadwear rating of 120-200 (examples: Toyo R1R, Dunlop Direzza Sport Z1 Star Spec, Bridgestone Potenza RE070, Kumho Ecsta XS, Yokohama Advan A046 & Neova AD08, Hankook R-S3) +2 Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted December 17, 2010 National Staff Share Posted December 17, 2010 Either way, it must be resubmitted. which section says that? It makes sense to have to resubmit your reclassification material if your car's listing changes, but I didn't find where it was required by the ruleset. It will say it in the TT Rules, and in the revised PT Rules that has the typo's corrected (like the missing line of car weights in the R's and S's). I just didn't want to hear Marks whoosing sound until after all of the rules and CC Forms are out. I don't need hundreds of re-class requests right now, just any rules issues that need to be fixed. It will also say it in the TT Rules announcement here and on the website. In fact, I'm wondering how many people are running on re-classes from '07 with base classes that have been adjusted since then Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted December 17, 2010 Share Posted December 17, 2010 ok good, just wanted to make sure I wasn't crazy and missing something Quote Link to comment Share on other sites More sharing options...
smokinjoe Posted December 17, 2010 Share Posted December 17, 2010 I need a reclass for more hp, less weight. How much should I send you Greg? Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted December 17, 2010 Share Posted December 17, 2010 greedy! I'd be happy staying at the same hp/weight and losing that damn asterix Quote Link to comment Share on other sites More sharing options...
smokinjoe Posted December 17, 2010 Share Posted December 17, 2010 Isnt that the same thing?! Weight ='s points ='s * Ken gets a triple *** for thinking inside the box Quote Link to comment Share on other sites More sharing options...
Trevor57 Posted December 17, 2010 Share Posted December 17, 2010 Where are the rules? The nasa-tt site has the old rules. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted December 17, 2010 Share Posted December 17, 2010 TT rules aren't out, but the car classing stuff will mirror PT & ST: http://www.nasaproracing.com/rules/performance_touring_rules.pdf if you're still getting last season's stuff you'll need to go through that refresh/clearing/whateverthehell process that Greg's talking about in post #1 Quote Link to comment Share on other sites More sharing options...
brkntrxn Posted December 17, 2010 Share Posted December 17, 2010 Looks like no changes for us C5Z06 racers. Unless I am missing something. (now I have to go save up for some A6s... again) Quote Link to comment Share on other sites More sharing options...
TurboShortBus Posted December 17, 2010 Share Posted December 17, 2010 3) DOT-approved R-compound tires with a UTQG treadwear rating of 50 to 130 (ex. Kumho V700, Michelin Pilot Sport Cup, Nitto NT01, Pirelli PZero Corsa, Toyo R888, Toyo RA-1, Yokahama A048, etc) +7 4) DOT-approved (non-R-compound) tires with a UTQG treadwear rating of 120-200 (examples: Toyo R1R, Dunlop Direzza Sport Z1 Star Spec, Bridgestone Potenza RE070, Kumho Ecsta XS, Yokohama Advan A046 & Neova AD08, Hankook R-S3) +2 Would there be a case where an unlisted brand and model of tire has a treadwear rating of 120 to 130, without any specific documentation to verify if it is an "R-comp" or not? If this was the case, then what would determine if it would be +2 or +7? There could be some confusion with the UTQG overlap of 50-130 and 120-200. Or, maybe the confusion is all mine. It happens. Mark Quote Link to comment Share on other sites More sharing options...
MSP608 Posted December 17, 2010 Share Posted December 17, 2010 Looks like no changes for us C5Z06 racers. Unless I am missing something. (now I have to go save up for some A6s... again) Adjustment factor for weight is a little different. Quote Link to comment Share on other sites More sharing options...
