jason Posted December 18, 2010 Share Posted December 18, 2010 I have a daily driver 1999 323is that my key switch broke. I've pulled the ignition switch apart and can turn it with a screwdriver, I get dash lights but no crank. I'd be more than willing to live with a switch and a push button, if there was a way to bypass all the security bs. I figured if anyone knew how to do this easily, it'd be you guys. Thanks for any help you can give me. Quote Link to comment Share on other sites More sharing options...
sean Posted December 18, 2010 Share Posted December 18, 2010 a 93 should not have ewsII it should be ewsI. you'll have to look at a wiring diagram to be certain, but i believe that system only uses a relay and if you jumper it will bypass the ews. Quote Link to comment Share on other sites More sharing options...
laze1 Posted December 18, 2010 Share Posted December 18, 2010 http://forums.bimmerforums.com/forum/showthread.php?p=20237882#post20237882&highlight=ews http://forums.bimmerforums.com/forum/showpost.php?p=19968899&postcount=1 http://www.europeantransmissions.com/Bulletin/DTC.BMW/understandthe%20EWS%20BMW.pdf http://www.yousendit.com/download/RlRwTXRmcGtZY1EwTVE9PQ http://www.yousendit.com/download/RlRwTXRjckk4aU5jR0E9PQ Quote Link to comment Share on other sites More sharing options...
jason Posted December 18, 2010 Author Share Posted December 18, 2010 Had the antenna wired wrong. Now I can at least get it started by holding the key to antenne and turning the switch by hand. Thanks for all the help. Learned a ton today. Quote Link to comment Share on other sites More sharing options...
laze1 Posted December 19, 2010 Share Posted December 19, 2010 cool! Quote Link to comment Share on other sites More sharing options...
