2011 NASA SE TTA Roll Call.
sperkins
  • Replies 165
  • Created
  • Last Reply
Top Posters In This Topic
  • sperkins
    22
  • drivinhardz06
    21
  • Varkwso
    17
  • Z06cool
    17
drivinhardz06
Man, Spec Z06 is really picking up speed.
Mark - are you running TTA? I don't see your name for PTA or TTA.
I'll mostly be hanging around RA this year, in PTA if I stay busy with work, TTA/instruct if I go broke
I got a 2 month old, 2 yr old, 5 yr old, and 2,321 house projects to tackle. can't do a full season this year, not enough hrs in the day.
my car is getting a cage right now, I'll be lucky to make it for RA/march
Link to post
With Scott signing up, I either need two more entries to join us or I need to drop out and save the tires and brakes.
You guys may not have to worry about me since I may never get this thing back together.
Scott, what kind of jacks do you use when its on the lift? I have tried the little short-throw canister-type units but they're a PITA. Is there a better way?
Link to post
"Might as well run some bigger tires and join us in TTS (the slower vettes;)."
The thought has crossed my mind. Except, I have already ordered the 275's.....
I will be on 275s most likely in tts.
...and will be a moving chicane just like last time...
Link to post
With Scott signing up, I either need two more entries to join us or I need to drop out and save the tires and brakes. No use in wasting equipment if there is no potential for gain.
Morris: 41's
If that happens, I know a certain black car that will be getting a tear down. And his "mechanic" will be coming up with some creative excuses for whatever is found.
Link to post
I have a center sliding jack that I use to raise the car. It will get it high enough to pull the wheel and do regular maintenance. When doing a clutch, it has to be much higher so I raise the car and set it down on some blocks with jacking pucks on top. Then I can use the center jack again to remove the rear cradle. A 2-post would be sooooooo nice.
Link to post
Better then my current option.
Link to post
hell I work on my car in at best a gravel driveway, having a paved surface would be an upgrade. Wish I had *that* problem...
A big guy could pick your car up.
Link to post
Beerkat could one hand lift it
Link to post
drivinhardz06
I'll leave some love notes hidden for varkwso
Link to post
Leave my car alone.....
Morris: 41's
Link to post
Scott, Mark or Jason - can one of you PM me BJ's cell number - I seem to have lost it.
I tried calling his shop last week and got voice mail.
TIA!
Link to post
Signed up today for TTA. I will miss a couple of sessions because of conflicts with my Teaching schedule.
I can drive it for you in those sessions . Unlikely for the FRC to make it to CMP - still need to pull drivetrain and lost my slave labor.
Link to post
I'm sure he doesn't want slower times...
Link to post
I've done two in the last month. I would say I'm getting better at it, but I'm not.
BTW - I have an 11" Spec stage 3 disc for sale if you know anyone that's interested.
Link to post
You always welcome to use my car.
Don't think he can do that unless he run backwards.
Link to post
Uhh...he does and sideways. You must have missed it when he stuffed Mike's car in the sand after the kink... Okay, maybe not having a steering wheel contributed...
Link to post
