raffaelli Posted August 7, 2003 Posted August 7, 2003 What marking are to be on the car during HPDE Quote
beerkat Posted August 7, 2003 Posted August 7, 2003 You should recevie a number for your car sometime before the HPDE event that you have sign up for. Quote
JKnight Posted August 7, 2003 Posted August 7, 2003 Beerkat, do you mean he'll get a number in the mail to affix to his car, or that he'll be assigned a number? It's early and I get confused easily. Jason Quote
Willard Posted August 7, 2003 Posted August 7, 2003 Beerkat, do you mean he'll get a number in the mail to affix to his car, or that he'll be assigned a number? You pick a number or two and are assigned one before the event. The numbers should be on the door (contrasting) not on the glass. I use low tack painters tape (1" wide) and it works quite well. Quote
Mule Posted August 7, 2003 Posted August 7, 2003 As long as you don't have a blue car. I use the same tape. It also works well for taping headlights. Helps to prevent debris from cracking or chipping glass/plastic. Quote
raffaelli Posted August 7, 2003 Author Posted August 7, 2003 You know...my car is the same color as the tape....strangest thing....at Limerock, they only could see numbers on the track and not my car!!!! I am shopping around for a set of magnetic numbers. So I thought that there might be some other markings like, HDPE level, novice, etc.... Quote
