Sign in to follow this
Marcus
Classing Help
Marcus
1990 Miata
99 1.8L swap - 1995 ECU and wiring harness
stock 5spd with stock VLSD diff
Koni Sports with GC sleeved coilovers
205-50-15 Bridgestone Potenza RE11 tires - 180 treadware
Flyin Miata front sway bar - rear sway bar removed
Jackson Racing header
Cat removed
Custom Exhaust
Cone Air filter
Full interior minus heater core and blower motor and AC box.
Dry weight probably around 2200lbs (will be more specific later after I get it scaled)
More or less looking to see if there was anything for the 99 swap. Rules cover a 94-97 1.8 swap, but nothing beyond that. Also covers the use of factory wiring harness and ECU. Am I somehow going to be stuck going power to weight? or can a base class be decided for just the swap? Personally I would gladly start with the 99 miata base class and base weight and take points from there. Just want to hear opinions on this.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
