GM LT1 350 with zero hours, w dry sump
GM LT1 350 with zero hours on build. Ready to install. Needs oil pan for your application.
Parts installed include.
Peterson 3 stage R4 dry sump
edlebrock lt4 intake
30lb bosch injectors
Comp EFI cam
Comp Cam steel roller rocker
Aluminum heads - GM
Meizer electric water pump
58 mm Throttle body
New optispark
ARP studs and hardware
Chrome valve covers
MSD ignition wires
Clevitt nascar bearings
Balanced and polished GM crank
Price $4500
Can package with 944 conversion, but motor is going first before other parts.
PM or email [email protected] for more info.
Available with wet sump pump and pan, 3299. Ready to install.
  • 2 weeks later...
  • 2 weeks later...
