1984 BMW 325e track/autox car
MM Chris
Here is a great project car for someone looking for an inexpensive way to get on track for HPDE's or to autox. The big ticket items have already been completed, and a lot of work has gone into the car. This is NOT an eligible model E30 for Spec E30, but a great HPDE car (good handling, lower powered, RWD).
As with many projects, this unfortunately was never completed. The good side to this is that it never made it to the track. All of the parts are basically brand new without wear (besides a few miles on the street). It is currently being stored at my parent's place in Powhatan, VA. I have not started it recently, as I feel it would better to take the time to properly do some fluid changes before starting. It needs a little attention and can be a lot of fun.
Features:
51,603 original miles!
Painted flat black
Welded in roll bar
Stripped interior and trunk, removal of air conditioning components and power steering
Interior and roll bar painted black
Sunroof delete and panel welded in place
Sparco circuit driver's seat with sliding adapter and mounting bracket
Sabelt racer passenger seat with fixed mounting bracket
Spec E30 race suspension: H&R race springs, Bilstein sport shocks
Powerflex control arm bushings
Rogue engineering rear shock mounts
Carbotech front Panther Plus pads, Axxis Ultimate rear pads
Stainless steel brake lines
Lug stud to wheel stud conversion
“Wink” rear view mirror
New exhaust muffler
Maintenance items completed: timing belt, water pump, alternator belt, distributor/wires/plugs, all new brake rotors, brake fluid flush with ATE superblue, air filter, intake boot, oil pressure switch, fuel filter, new battery
Fluids changed: oil, coolant, transmission and differential (redline products)
Immediate needs:
Alignment
Tires
Small section of the floor pan under the battery in the trunk is a little rusted- simply need to cut this out and weld in a new section
Harnesses for the seats (if it were to be tracked)
Hood release cable
Coolant sending unit (have one, included with car) I believe needs replacement- gauge was not accurate
I have the maintenance records for the work my friend and I completed on this and lots of current pictures that can be emailed. I have a couple of boxes of random parts, an extra rear bumper, and some other things that will be included based on the sale price.
Price is $3,000. Located in Powhatan, VA. This will need to be trailered. I have a trailer and can transport it for an additional fee based on your location. Please contact Chris at [email protected] for any questions and pictures (I have many more I can send you in a google Picasa link).
  • 9 months later...
My e30 is still available! I haven't been actively selling it for some time, so have decided to lower the price as I need to make some room. Please contact me via email with any questions.
