MDizzle Posted May 18, 2011 Share Posted May 18, 2011 Ideally, the best wheels are the basketweaves off an E34 which are 15x7 et20 correct? I'm looking for an additional set of wheels...and I've come across 15x7 et20's that claim to be off of an E39 (the 5 series younger than the E34); however, I thought that the E34 and E39 wheels are not interchangeable. Is it that the hubs that are different? I realize that the 15x7 basketweaves of the E30 M3 look the same also, but they are et30 and therefore do not fall within the rules. What am I missing here? Quote Link to comment Share on other sites More sharing options...
whaden Posted May 18, 2011 Share Posted May 18, 2011 IIRC...The e39's have a different hub center bore than the e34, but a hub centric ring will fix it. http://www.amazon.com/Gorilla-Automotive-74-7256-Centric-72-56mm/dp/B002803R4G/ref=sr_1_1?s=automotive&ie=UTF8&qid=1295924492&sr=1-1 Quote Link to comment Share on other sites More sharing options...
dbgeek Posted May 18, 2011 Share Posted May 18, 2011 I am running exclusively E39 wheels without rings. I simply make sure I torque the lug nuts in a star pattern progressively. Perhaps I should buy some. the plastic ones get brittle and crack up after a year or so. Tire Rack sells Aluminium ones that are more durable. I just called TireRack "We will provide them with wheels we sell, but will not sell them individually." poop Quote Link to comment Share on other sites More sharing options...
whaden Posted May 18, 2011 Share Posted May 18, 2011 Poop indeed. I have a set of the e39s now and the rings on order. I'm not to worried about the brittleness though. I'll put my rains on these and hopefully not need them as much. (regrets typing this immediately ) At the price...it's not to difficult to replace them, even on my budget. Quote Link to comment Share on other sites More sharing options...
dbgeek Posted May 18, 2011 Share Posted May 18, 2011 At the price...it's not to difficult to replace them, even on my budget. My thoughts exactly. I picked up 2 sets from Amazon - not the gorillas, but mr lugs or whatever. Quote Link to comment Share on other sites More sharing options...
sean Posted May 19, 2011 Share Posted May 19, 2011 You can find metal hubcrntric rings on eBay. Quote Link to comment Share on other sites More sharing options...
ScoobyDuck Posted May 20, 2011 Share Posted May 20, 2011 I've been running 17" e39 wheels in order to kill off some left over RA-1s from the Subaru. Tried using new plastic rings and they cracked while trying to install them. Haven't used them since and have had no issues. Quote Link to comment Share on other sites More sharing options...
dbgeek Posted May 20, 2011 Share Posted May 20, 2011 I haven't been using rings... Then, on the Bimmerworld dyno, Jason points at the rear wheel during a run. It was quite obviously not centered. I'll run rings just for piece of mind. Quote Link to comment Share on other sites More sharing options...
MDizzle Posted July 20, 2011 Author Share Posted July 20, 2011 E34 wheels...same kind that anders uses I believe. Posting them up for a friend, figured I'd advertise here too. http://forums.bimmerforums.com/forum/showthread.php?p=22377536#post22377536 Quote Link to comment Share on other sites More sharing options...
Scany Posted July 21, 2011 Share Posted July 21, 2011 E34 wheels...same kind that anders uses I believe. Posting them up for a friend, figured I'd advertise here too. http://forums.bimmerforums.com/forum/showthread.php?p=22377536#post22377536 Great wheels! But if they are not balanced with weights of gold, I try to pick them up for around $25-$35 a piece I need one more set. Quote Link to comment Share on other sites More sharing options...
