miatagrin Posted September 9, 2011 Share Posted September 9, 2011 I'm looking at adding a lower rear chassis brace to a Miata. Section F (Brakes/Chassis), Rule F.4 of the TT Classification seems to indicate that this modification is +3 points to add a brace with greater than two attachment points. The overall rule states "Add or modify other chassis stiffening devices ...". If I add a brace with two connection points, do I need to take +3 TT points? Thanks. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted September 9, 2011 Share Posted September 9, 2011 It would need to meet free mods F-8, 9 or 10 to be points free based on what I understand, otherwise take the points (and make the points worth it) or don't run the part Quote Link to comment Share on other sites More sharing options...
Joshua Posted September 14, 2011 Share Posted September 14, 2011 Your 1991 Miata is on the same line (Miata 1.6 liter) as the 1993 Miata. So, if I'm not mistaken, you may update to the rear subframe from a 1993 that allows the use of the OEM rear, lower cross brace. It attaches at two points to welded tabs on the subframe. If this is valid, that's 0 points for a slight improvement in rigidity for a small increase in weight. Quote Link to comment Share on other sites More sharing options...
