Fender Roll - In?
Does any one have pictures or further clarification on this rule?
"Front and rear wheel fender opening lips may be rolled inward to maximize tire/wheel clearance."
I'm asking because the only fender rollers I'm aware of roll the fenders out, and I'm going for maximum allowable track width on my 924S.
Thanks,
sm00thindian
You can take the inside lip which is normally shaped like and L and make it flat. This gives maybe a 1/4" more clearance to the fender. The outside profile of the fender must remain stock. The 924S can fit 225/50 R15 tires, but it can be a little close. You will not get to the same track width of a 944. However in practice this makes no difference as the 924S is just as fast as a 944 body.
