rtosborne Posted October 10, 2011 Share Posted October 10, 2011 I did a search and found some info but thought I would try to get a specific, decisive answer. As stated, 2000 Civic Si. Currently SSC trim but moving towards HC trim. What tire size are people running? What offset wheel is required to run that size? What is required to run that combo (rolling fender, etc.)? Thanks, Rory Quote Link to comment Share on other sites More sharing options...
rtosborne Posted October 14, 2011 Author Share Posted October 14, 2011 Any ideas? Quote Link to comment Share on other sites More sharing options...
vbspec Posted October 14, 2011 Share Posted October 14, 2011 if its an HC2-HC5 car its a 225/45/15 and a 15x7 wheel.. Any 38-45mm offset works fine and you may have to roll the rear fenders a tiny bit Quote Link to comment Share on other sites More sharing options...
rtosborne Posted October 15, 2011 Author Share Posted October 15, 2011 Thanks. Anyone else have any first hand experience with this combo? Quote Link to comment Share on other sites More sharing options...
Karl Posted October 17, 2011 Share Posted October 17, 2011 most of the cars I have seen in h2 run the 225-45-15 on a 15x7, mine included Quote Link to comment Share on other sites More sharing options...
ILIKETODRIVE Posted October 17, 2011 Share Posted October 17, 2011 I ran 225/45 NT-01 and 15x7 +43 TE37 in TTE for 2009 & 2010. Basically the same combo. Worked very well. Quote Link to comment Share on other sites More sharing options...
Calif_Kid Posted October 19, 2011 Share Posted October 19, 2011 I'm running 225/45-15 RA1s on 15x7 Enkei RPF1's in an ET35 offset, plus have spacers (8mm, I believe) in the front. The RPF1's are really light, but step down near the outer edge of the wheel, so my brake calipers and brackets had to be ground for clearance. Main thing is that an ET35 offset probably will also work. - Jim Quote Link to comment Share on other sites More sharing options...
Lo-bucK Posted October 19, 2011 Share Posted October 19, 2011 All the above info is dead on. Any 15x7 +35-43 will work. Rear inner fender lip has to be rolled for most set ups. Quote Link to comment Share on other sites More sharing options...
