2001 24' HAULMARK FINISHED ENCLOSED CAR TRAILER
2001 24' HAULMARK FINISHED ENCLOSED CAR TRAILER $4500
Tires in great condition with plenty of tread.
I can email pictures.
Diamond plate flooring, Working A/C will freeze you out. Two windows, Room with shower, water heater and vanity and light..only! counter in main ares holds water heater, fuse panel. plenty of room for extra stuff. Walls are white heavy sheets of 1/4" vinyl. Walls and ceiling are isolated. two wall mounted shop lights. Brand new 24' awning and Electric jack with a light. Rear door is diamond plated. Rear has heavy plastic strips hanging to keep a/c in trailer when door is open. wall mounted stainless steel cans & air hose holder. Trailer is wired for generator or plugged into outlet, 100' heavy cord for plug in.
I have a Yamaha 4500 NEW generator does not come with trailer but will sell separate. EF4500iSE
Yamaha 4500watt Consumer Inverter Generator.
Weighing only 194lbs., the EF4500iSE is the perfect solution for your portable power needs. Producing high-quality clean power, the EF4500iSE revolutionary Yamaha engine is both extremely powerful and quiet. This model is a mid-size portable generator, Perfect for camping and RVing â€" capable of running an air conditioner, microwave oven and more all at the same time. The 357cc Yamaha 4-stroke OHV engine was certified to the most stringent California Air Resources Board Tier III exhaust emission regulations and durability levels.
Sound Rating = 58-60 dBA
Generator retails for $3,060.00 plus tax $242.44 =$3,302.44
I will sell it for $2,500.00...You will save $812.44
Trailer does not leak. Roof was resealed at lone star RV in July 2010.
Sounds like what I've been looking for....wish you were closer to VA.
  • 4 weeks later...
