ELO168 Posted November 16, 2011 Share Posted November 16, 2011 Anyone have one for sale? Quote Link to comment Share on other sites More sharing options...
ILIKETODRIVE Posted November 16, 2011 Share Posted November 16, 2011 D-Series? B-Series? K-Series? Quote Link to comment Share on other sites More sharing options...
ELO168 Posted November 16, 2011 Author Share Posted November 16, 2011 Sorry should have mention that. Is for a D16 for my H4 car. Thanks Quote Link to comment Share on other sites More sharing options...
ILIKETODRIVE Posted November 17, 2011 Share Posted November 17, 2011 If no one on here has a used one for sale, I recommend http://www.teammfactory.com/ Quote Link to comment Share on other sites More sharing options...
ELO168 Posted November 18, 2011 Author Share Posted November 18, 2011 How do I know if need the 35 or 40MM? My car is a 1989 CRX DX and previous owner swap to SI Thanks Quote Link to comment Share on other sites More sharing options...
jmeris Posted November 18, 2011 Share Posted November 18, 2011 How do I know if need the 35 or 40MM?My car is a 1989 CRX DX and previous owner swap to SI Thanks You remove, the transmission from your car (or pay someone to do it) and crack it open and measure..how else would you know for sure?! Sure beats ordering the wrong lsd and trying to install it, then sending it back, re-ordering, and then finally installing it. Quote Link to comment Share on other sites More sharing options...
ELO168 Posted November 18, 2011 Author Share Posted November 18, 2011 How do I know if need the 35 or 40MM?My car is a 1989 CRX DX and previous owner swap to SI Thanks You remove, the transmission from your car (or pay someone to do it) and crack it open and measure..how else would you know for sure?! Sure beats ordering the wrong lsd and trying to install it, then sending it back, re-ordering, and then finally installing it. Is that the only way or it can be read form the # on the tranny. Also the mm is ID or OD? Thanks Quote Link to comment Share on other sites More sharing options...
H4CRXSi Posted November 18, 2011 Share Posted November 18, 2011 Feel free to send me the numbering from the case and I'll see if my trans guru buddy can decipher to see if it is from a DX or Si. Also, I have a friend who is a dealer for MFactory, and we just installed one of their metal plate diffs in the CRX that he and I co-drove this season and what a difference it was over the Quaife that we had in the car previously. If you want to, contact me directly and I can get you some more info: smyersjr "at" att "dot" net Regards, Sam Quote Link to comment Share on other sites More sharing options...
jmeris Posted November 18, 2011 Share Posted November 18, 2011 Is that the only way or it can be read form the # on the tranny. Also the mm is ID or OD? Thanks It's probably the most sure way to confirm what size you have. Using the tranny code might not work because if i remember correctly, most of those EF tranny's were coded "L3"??? Also, if the previous owner replaced the diff with a different size than the original, you'll need to measure. Quote Link to comment Share on other sites More sharing options...
ILIKETODRIVE Posted November 18, 2011 Share Posted November 18, 2011 I was on d-series.org for the longest time years ago. Look here: IF I remember right, PL3/A000 and PL3/A100 are small bearing cases. PL3/3000 PL3/6000 PL3/9000 PL3/B000 are large bearing cases. Like Meris said, only 100% for sure way is crack it open and measure. Quote Link to comment Share on other sites More sharing options...
ELO168 Posted February 19, 2012 Author Share Posted February 19, 2012 Still looking for one with 35mm, prefer Mfactory. Thanks. Quote Link to comment Share on other sites More sharing options...
