Joshua
An History of NASA Florida Time Trial Records - 2011
Joshua
How much could be gained by getting a good alignment? Mine is a bit off (camber LF -2, RF -2.7, LR -1.9, RR -2.5) and am considering getting camber arms to correct it (front -3, rear -2), are the +4pts worth it?
I don't know about the Z cars, but in a Miata, proper setup doesn't necessarily mean dramatic reductions in lap times, but it does make the car more consistent and controllable. To me, that's the main benefit of a good alignment - it makes it easier for amateurs like me to drive the car with more confidence and consistency.
Share this post
Link to post
l30thelion
Thanks for the input. It's tough at times to resist the urge to keep upgrading the car expecting huge gains. I'm hoping the control arms will "complete" the car's suspension, that and a great deal on them, is the reason I'm going to upgrade soon. But, then I won't be able to run TTD anymore w/o going back to 3370lbs/235hp
Share this post
Link to post
Joshua
If I've learned anything over the past few years, it's that you shouldn't listen to most of the advice you hear about cars. The only way to really know if parts or adjustments will help you out is to try them yourself and test, test, test. Based on your results at Homestead, you've inspired me to try A6 tires at the next event. I happen to have a set sitting in the garage that I have not yet used on the track - just at the last autocross event at Fort Myers.
Share this post
Link to post
BlkGt3
Moton CS was worth over 2 secs on the GT3 probably the only downside to 3/4 way shocks (besides $$$$$$$) is getting them set up properly.
Peter
I'm running DA konis and don't know what the hell I'm doing......so I leave them in the mid setting and hope for the best.
Correct camber will help grip in turns allowing more speed. What Joshua said about Internet info is correct as you need to separate the wheat from all the chaff. Without long winded discussions about tire temps etc. I would shoot for -2.0 rear and -2.8 front and go from there if you want to experiment. On the M3 all I can get is -1.7 rear and feel control arms are not worth the extra 4 points. Come to TTC we need a rabbit to chase
Peter
Share this post
Link to post
l30thelion
A6s, uh-oh! Well, it has to be done, the record must be taken back.
I'm learning the hard way. I spent a ton of money on the OS Giken LSD and really don't think my car needed it. The 350Z forums were full of posts w/ people saying how it is a gotta have mod. It may be that I just don't really know how to get the most out of it, either way I'm pretty sure that the money could have been better spent on other mods. On the other hand, changing the gears on the rear end made a WORLD of difference, for me that is a gotta have mod. Acceleration is insane now! It requires more shifting but is well worth it. The Ft. Myers course was a pain, I had to shift from 2nd-3rd-2nd a few times, I'm used to just staying in 2nd.
Damn, sounds like you guys really know how to setup a car, I'm sure having Ian on your team helps (saw him featured in a tech article on GRM I think). The SCCA T2 350Z folks do lots of testing, they take that sh!t seriously. The -2/-2.8 numbers is right about where the Z guys recommend, though some go up to -3.5 up front. I've heard it mentioned that the wider the tire the less neg camber required, is that true?
Thanks for all the advice/answers, appreciate it.
Share this post
Link to post
Mrsideways
This is true, But this is what I'm looking at...
Yes the T2 car would likely slide into TTB but....
The Nismo Aero does essentially nothing... Remove that -4
The 10pt shocks can be done just as good as 3 point shocks -7
The springs are really just glorified Eibach lowering springs so you put real springs on (FASTER)
The Brakes in a TT car really do nothing so -2
Add enough spring that you don't need sway bars -2
Run a 225 tire (essentially same size as a 245... thanks hoosier) Total of 3 points in the tires
19points... TTC! And within a couple 10ths of a T2 car.
You run a 225 tire so you get an adjusted power to weight of 11.2:1 which at 3168lbs that gives you 283whp. (probably higher then what the T2 cars are making).
That is all fine and dandy but then he will never see 27ns in that set up. Common Ian 3 way Motons, I put those on my car and I am 1.5 seconds faster minimum.
NO WAY. That means your current setup is garbage. Chi has Single adjustable AST's on his S2000 and his car is EVERY bit as quick as mine with 10pt shocks if you factor in the weight difference. In fact when I ran my car in TTB last year (still sorting it out) The ONLY thing that made it a TTB car was the 10 pnt shocks. I could have put chi's shocks on ran the same time and lowered the TTC record.
Pete is saying the Moton's were 2 seconds faster on the GT3 at sebring but that's over STOCK suspension. Whats the difference between Moton single adjustable and the Moton doubles... couple 100ths of a second maybe.
Think about it all the triple adjustable shocks really get you is adjustment. Someone valving it right the first time essentially means you could run 3 point shocks just as good as 10pt shocks.
It will take time but you will start to see the SCCA cars come over. But you need to do something to attract them.
Share this post
Link to post
32EVOIX
Why didn’t you? In fact why then did you spend the money on 10 point shocks if they are the same?
Depends who is driving!
Oh now we are talking about re-valving the shocks, I haven’t checked the rules lately on this but is that legal without points (maybe Mark can chime in). Besides you are comparing apples and oranges now.
Like what? What does the SCCA offer that we do not?
Well you do have a point on my set up, I run Tein Mono Flex, AST's, Motons, or KW's would lower the lap times substantialy.
But back to the "fast" SCCA guys we keep hearing about them but they don't show up anywhere, not at local nor at National, where are these Shumachers? My father always told me get "if" out of the vocubulary, becasue it dosen't mean a hill of beans. If the Queen had balls she would be King, get them out here so they can show us all how to drive. I know I am always looking to learn.
Share this post
Link to post
TurboShortBus
Here are the 2011 rules for shocks/struts in TT:
E1) Non-OEM shocks/struts/dampers with an external reservoir or more than two ranges of adjustment—must still take
points for springs below +10 (example: compression (bump) and both high & low rebound adjustments).
E2) Non-OEM shocks/struts/dampers with a “Piggy Back” external reservoir (fixed reservoir without a connecting hose) OR
with shaft diameter 40mm or greater—must still take additional points for the springs below +7
E3) Non-OEM or modified/re-valved shocks/struts/dampers +3 (all others) (springs not included)
You can re-valve non-OEM shocks all you want for no additional points, as long as they meet the rest of the guidelines above. Re-valving OEM shocks will rack up +3 points per E3.
Find some non-reservoir shocks with a 39mm diameter shaft and only 2 ranges of adjustment, re-valve them to your application, and they will only cost you +3 points.
Mark
Share this post
Link to post
Mrsideways
Why does the car have remote reservoir shocks?.... Cause it's built for SCCA and they have a shock rule that makes sense. Not some arbitrary rule attempting to curb costs. I never planned to campaign in with NASA in any kind of serious fashion, No competition for what the car is made to do. The SCCA Rules don't carry over very well, My splitter has to be Tiny by NASA standards yet I take the full points hit for a nearly worthless item, Same story on the Wing. Take a HUGE hit in points for not very much weight out of the vehicle. Have to run Tiny tires (per SCCA) and can't flare fenders to put big tires on for NASA. So to make the car competitive in NASA The car would no longer be SCCA legal. To keep the car built to where it needs to be in SCCA I have to run on Tiny tires with No HP compared to the NASA cars I've now bit upped into the class of.
Now I'll run it in PTA against Joesph because as a Built STU car it should run close to Joseph and James, They'll still have way more tire and way more power and way more downforce then me, But I think I can drive well enough to make it interesting. Now Nationally it's got nothing for the PTA cars so it won't go to Nationals.
Shock valving must be opened, When I ordered my Mini Shocks from AST I said I want them valved this way for this spring and this tire... Done deal I essentially had 10pt shocks for 3 pts.
Now Jimmy, How about this for an EVO time so you can make sense of it.
Marty Grand (current T2 National Champion in a EVO)
Same kinda mods as the 350z, Off the shelf springs, Open shocks, Open Diff rules.
In STU trim he has to slow the car down and run 8 inch wheels and a 41mm Turbo Inlet restrictor designed to keep the car under 300whp. And a Min weight of 3430lbs
Marty Did a 2:10.0 at VIR last year in the race. Oh and BTW his car is streetable, He drove it home after a race in atlanta last year.
http://www.mylaps.com/results/showrun.jsp?id=1837056&perclass=1
Evo all Stock except as noted.... Shocks, Diff, ecu flash.
Permacool trans. oil cooler #1006 or Setrab #SET616 and Mocal
pump # MOC-17522HT, AMS front and rear springs #AMS-SCCA01 allowed or AMS front and rear spring kit #AMS-SCCA02
including Genesis Technologies 2’’ spacer allowed. 41mm Turbo
Inlet Restrictor required. Koyo Radiator #KOY-R2676 allowed.
Alternate AMS front sway bar permitted #AMS-SCCA-SBF02,
alternate rear sway bar permitted #AMS-SCCA-SBR02
Nasa doesn't draw the SCCA cars out the same way Redline Time Attack doesn't draw the NASA Guys out. Redlime Time Attack came to sebring and I think I was the ONLY NASA guy down here who ran it. Jimmy, why weren't you there?
Lack of Competition in Redline?
Rules set doesn't cater to your car?
No prize money in comparison?
You tell me?
Or perhaps coverage like this.....
Share this post
Link to post
TurboShortBus
Why would anybody enter a race where the rules set didn't cater to their car? That would be the same as intentionally bringing a knife to a gun fight. I wouldn't fault somebody for skipping an event for that reason.
This is just another example of why cars built to X rules aren't competitive or legal in a class that runs Y rules, just like a Miata built for TTE is a lot different than a Spec Miata that runs in TTE, or a Miata built for TTD is a lot different than a Spec Miata that runs in TTD, or why a CMC Mustang would get its ass kicked in TTB. There are tons of sets of rules out there, and you cannot expect them to grant equality from class to class or club to club. Would it be convenient if they did? Of course it would, but that means that both groups would need to revise their rules a bit, or one group would have to do a serious overhaul of their rules, all of which is at the risk of offending the existing participants who don't wish to change classes/clubs or don't have the funds to radically change their cars to stay competitive and legal (while hoping that you are able to pick up new drivers, of which there is no guarantee).
Mark
Share this post
Link to post
Mrsideways
Mark
Exactly, But when asked how fast can a class go... I can look at those cars and say.... Well it's essentially the same even though it doesn't match the rule set exactly I can tell you that's how fast you "SHOULD" be able to go. That is all. Some asked how fast a Z can go in TTC trim... I think pretty darn close to a Z in T2 trim.
Share this post
Link to post
TurboShortBus
Bring 'em out, then. That is all.
Mark
Share this post
Link to post
Mrsideways
Mark
You won't get em. They live all over the country it's a long haul down here to run a regional event with minimal competition for classes the cars aren't built for. Just cause they aren't here doesn't mean the times don't exsist and you shouldn't strive to run those times.... It's like walking around pretending your the best basketball player in the world just cause someone from the NBA won't come play at your local court.
Share this post
Link to post
Balroks
Jumping in just for technical sake.
Marty is a hell of a driver (and all around sportsman). There are modifications there you didn't list he has which makes significant improvements on lap times for the Evo which Jimmy does not have (and neither do I at this point). Also while he's got the 41mm restrictor, it allows [email protected] to tune the torque through the roof. All while on the stock engine still which we're all very proud of. And he races on A6's, i'm assuming also because the SCCA sprints are shorter as I've tried it with mixed results.
Also for RTA, cmon. The STREET tire Evo that won I think which was the Professional Awesome guys in the Evo7, have 550hp to the wheels with all the drivetrain goodies. The next ruleset up MODIFIED, which Gates and a few others run had 750+HP, running 2:10's in practice on NT01 tires before he had electrical issues. Don't remember what the others did that day but was fun to spectate. RTA rules just weren't worth the $ it takes to demod or to seriously mod to the RTA standard those days, even for my car which is levels above Jimmy's. However i'd bet if we put you or Jimmy in that Evo7 it woulda gained whole seconds still.
Share this post
Link to post
Mrsideways
Wait Wait Wait I was there. It was a joke 90% of the cars were SLOW SLOW SLOW for the mods they had done. Favorite was the supercharged S2000 running mid 2:40's. The FASTEST car of the weekend did a 2:16 and that was done by Tony who I know from the One Lap of America. He's VERY fast.
As for Marty's car. Either you or Jimmy could go see AMS and tune your TQ though the roof if you want. Marty is a Great driver but isn't that what this debate is all about. SCCA Races are 45miles. A6's work but they are dead in one race.
I use to Run in Touring, The basic jest of the class is Stock, Allowed to change shocks, Allowed to change Exhaust up to(and including the CAT), Allowed to change the Diff, All other mods you MUST request an allowance, I posted the Evo's allowed Mods. And it still doesn't change the fact that the thing weights 3400lbs!!!!! running on 8 inch wide wheels. If your saying Marty has more then that your accusing him of Cheating. Read the rules.
Rules for T2
Starts on page 653.
http://scca.cdn.racersites.com/prod/Documents/2011%20Tech/2011%20GCR-printed%20version.pdf
These Specifications are part of the SCCA General Competition Rules
(GCR), and all classified automobiles shall conform with the requirements
of GCR Section 9 unless this Category is specifically exempted from said
requirements.
A. Purpose
Touring Category Classes are intended to provide the Membership with
the opportunity to compete in commonly-available, recently-produced
automobiles in as near the legal, street-driven form of those automobiles
as is practically and safely possible under racing circumstances.
B. Intent
Touring Category automobiles shall, at all times, be in compliance with
the specifications contained within their factory Shop/Service Manual(s)
except as modified by these rules. Factory Shop/Service Manuals may
come in the form of printed material, microfiche, CDs, DVDs and/or
Internet access to manufacturer sponsored web-based databases. It is the
responsibility of the competitor to provide the electronic device capable of
accessing the data for compliance verification.
1. The competitiveness of any car in any Class shall not be guaranteed, nor shall the continued recognition of any car in any Class.
Eligibility of cars may be discontinued at any time and for any
reason, other than that of competitive stature.
C. Specifications
The SCCA shall publish Touring Category Specifications (TCS), containing
the basic officially recognized specifications for each car eligible to
compete in the Category during the calendar year.
1. To supplement those Specifications, competitors in the Touring
Category shall be required to have in their possession a factory
Shop/Service manual or its equivalent (See TCS section 9.1.10.B)
for the specific make, model and year of the automobile entered.
This manual or its equivalent will assist in determining the originality and configuration of the automobile, and shall be presented
at Technical Inspection for every event and when otherwise so
officially requested. If the factory Shop/Service manual is not available, then the competitor shall have a copy of the official SCCA
Vehicle Technical Sheet (VTS) with them at every event and shall
present it for reference when officially requested.GCR - 654
9.1.10. Touring Category Specifications
2. The proof of legality or illegality shall rest upon the protestor and/
or protestee.
3. The Club Racing Board may classify any particular model of a
car, and may permit specific factory options for that car. Such
options shall be listed on the Specification Line for that vehicle. No
unlisted models or factory options are eligible. If no specific model
or options are listed on said line, the classified car shall be the base
model with no options. Converting a car delivered with an automatic transmission to a manual transmission is allowed as long as
all components which differ, including, but not limited to, radiator,
springs, engine management systems, final drive ratio, etc., are
converted to manual transmission specification.
a. Only those cars listed each year are eligible to compete. Additions and/or deletions of automobiles shall be at the discretion
of the SCCA.
b. “Special Performance” specifications from the manufacturer
which go beyond those listed in the Touring Specifications
book will not be considered valid. Any manufacturer determined to be supplying false specifications to competitors or
to the SCCA may be advised that said specifications may be
withdrawn or the eligibility of the car(s) involved shall be terminated. The Club Racing Board is authorized to implement these
terminations on an immediate basis without the approval of the
Board of Directors.
c. In the case of service circulars, recalls, etc., the burden of
proof of validity shall be upon the competitor.
4. To maintain the stock basis of Touring, updating and/or backdating
of components is only permitted within cars of the same make and
model as listed on a single Touring Specification Line. Interchanging
of parts between engines of varying displacements is prohibited.
a. The Club may permit substitution/replacement of certain
components or modification of some assemblies on Touring
Category automobiles. To assist in equating competition potential, not all automobiles may be permitted some or all of these
allowed substitutions and/or modifications. Any such permissions shall be listed on the Specification line for each vehicle.
b. Cars will be eligible for competition from the time they are classified until the end of the tenth calendar year of competition of
the latest model year listed on the specification line.
5. The Vehicle Identification Number (VIN) shall correspond with the
automobile classified and the automobile presented for competition. VIN stampings and/or plates shall remain in place.
a. A car may be entered in competition if there are a minimum of
two (2) VIN stampings and/or plates that correspond with the
model of automobile classified.
b. The tenth (10) position letter of the VIN determines the model
year of the car (“W” = 1998, “X” = 1999, “Y” = 2000, “1”
= 2001, “2” = 2002, “3” = 2003, etc.).
6. In order to equate competition potential, the Club may specify a
competition weight for the vehicle. Additionally, and to this same
end, it may direct that a specific amount of ballast be mounted in
the vehicle in a specific location. Refer to Section E.2. of these
Rules for additional details.GCR - 655
TCS
7. When alternate parts are approved for competitor use, the
requesting party must first provide proof that sufficient quantities
of the parts are readily available through commercial channels. The
kit must be submitted to SCCA Club Racing Technical Services for
inspection, and the kit may be returned to the sender.
D. Modifications (Configuration)
The following items represent the only modifications and safety items
permitted and/or required on Touring Category automobiles. No permitted
component or authorized modification shall additionally perform a prohibited function.
1. Engine
a. Component Modification
1. Overhaul procedures which in the slightest way could
increase performance beyond factory specifications shall
not be utilized, e.g. porting/polishing, etc.
2. Blueprinting and balancing is allowed.
3. No engine component(s) shall be modified in any manner
that is not specifically permitted or authorized by the
Factory Service Manual or legitimate Factory Technical
Bulletins.
4. “Special Performance” specifications from the manufacturer which go beyond those listed in the TCS book shall
b. Induction System
1. Air Filter(s) elements (only) may be substituted.
c. Fuel System
1. All fuel system components, settings, and specifications
shall be as specified by the manufacturer. Fuel filters may
be substituted with other fuel filters of equivalent OEM
specifications.
2. Only the fuel type specified by the Owner’s and/or Factory
Service Manual may be used. Refer to GCR Section 9.3
Fuel, for permitted fuel specifications.
3. The stock fuel tank may be replaced with a fuel cell that
is designed to mount in the OEM fuel tank location or
is specifically designed to mount in the spare tire well
provided that it is not necessary to modify any bodywork
to accomplish the installation other than for the purposes
of fastening the cell securely in place.
d. Camshaft and Valve Gear
1. All valve sizes, seat dimensions, and angles, etc., shall be
in conformance with those specifications and procedures
outlined in the Factory Service manual.
e. Block
1. Cylinder bore dimensions shall remain as originally specified by the Factory Service Manual. No “oversize” bores
shall be permitted.
f. Oiling System
1. Engine oil may be substituted with other oil of equivalent
OEM specifications. Oil additives are unrestricted.
2. Engine oil filter may be substituted with any unit meeting
OEM specifications.GCR - 656
3. An oil catch can is permitted.
4. Any oil cooler(s) is permitted.
g. Ignition/Starter/Electrical System
1. Spark plugs may be substituted.
2. The use of resistor or non-resistor-type plugs is permitted.
3. Batteries may be replaced with those of an alternate manufacturer, provided they are of similar amp-hour capacity,
size, and weight.
h. Exhaust System
1. All cars classified in Touring may replace the catalytic
converter(s) with a pipe that has the same diameter inlet
and outlet as the converter it is replacing. The post catalytic converter oxygen sensor may be disabled, replaced,
or removed; the resulting hole (if present) may be plugged.
All Touring cars may replace any part of the exhaust
system beyond the catalytic converter(s), provided:
a. Said replacement system retains the original configuration, e.g., single or dual, etc.
b. The system exits from beneath the body in the same
approximate location(s) as the original system. When
a factory (OEM) single exhaust system is cosmetically
split into dual outlets, it is permitted to continue as a
single system provided it exits in approximately the
same location as one of the originals.
c. The system meets all appropriate event-specific sound
level requirements.
i. Other Engine Components
1. Fluid hoses, their appropriate clamps, and belts (fan, alternator, etc.) may be substituted. Related clamps and hardware are unrestricted.
2. The engine management computer or ECU may be altered,
but not replaced. All modifications shall be done within
the original housing. The car may meet federal emission
standards, but shall provide OBD II compliant data to the
data link connector.
3. Cosmetic engine covers made of plastic may be removed.
4. Any power steering cooler(s) is permitted.
2. Engine, Rotary Piston
a. All permissions and restrictions in Sections D.1.a. - m. apply.
3. Cooling System
a. Radiator(s)
1. A radiator screen of one-fourth (¼) inch minimum mesh
may be added in front of the radiator. If added, it shall be
contained entirely within the bodywork of the vehicle.
2. Any radiator is permitted, provided it mounts in the original
location, maintains the same plane as the original core,
and requires no body or structural modifications to install.
No new openings created by fitting an alternate radiator
may be used to duct air to the engine.
b. Air Conditioners:GCR - 657
TCS
1. The factory and/or aftermarket air conditioning system
may be removed, provided that at least the following items
associated with the system are also removed: compressor,
condenser, H.D. springs/sway bars, H.D. shocks, larger
tires, engine and transmission coolers and cooling fans.
All duct work, wiring, Freon lines, valves, evaporators,
dryers, and dash controls may remain. If the air conditioning compressor is an integral part of the drive system,
the compressor may be retained and disabled or replaced
with an idler pulley that serves no other purpose.
2. Items that serve a dual purpose, such as an alternator/air
conditioning compressor bracket, etc., may not be substituted.
3. The gaps around the radiator that are created by the
removal of the air conditioning condenser and related
items may be sealed with foam.
4. Transmission/Final Drive
a. Transmission
1. Transmission lubricant may be substituted. Transmission
lubricant additives are unrestricted.
2. An oili catch can is permitted.
3. Any transmission cooler(s) is permitted.
b. Final Drive
1. Unless otherwise so noted on the Vehicle’s Specification
Line, the differential ratio shall be as delivered as standard
equipment by the manufacturer.
2. All legitimately classified cars in Touring Class are
permitted a limited-slip differential (Quaiffe, Torsen, etc.).
Locked differentials are not allowed.
3. Final Drive lubricant may be substituted. Final Drive lubricant additives are unrestricted.
4. An oili catch can is permitted.
5. Suspension
a. Suspension Components
1. Adjustment is permitted with a maximum negative camber
of 3 degrees.
b. Springs, Anti-Roll bar(s), and Shock Absorbers
1. Springs and anti-roll bar(s), shall remain as manufactured
unless an alternate is listed on the vehicle specification
line. Cars where air conditioning units have been removed
shall refer additionally to Section D.3.b.1., above, for additional spring requirements.
2. The make of shock absorber may be changed. Their
number, perch location(s), system of attachment, and
attachment points shall not be altered. Their type (tube
vs. lever, etc.) shall not be altered. The interchange of gas
and hydraulic shock absorbers is permitted.
a. The mounting hardware utilized shall be of the original
type.
b. The use of any shock absorber bushing material is
permitted. Note: the bushing attaching the end of the GCR - 658
strut to the body or frame on a strut-type suspension system is considered a suspension bushing, not a
shock absorber bushing.
c. The placement of the spring shall remain as stock. The
distance between the lower mounting bolt, or other
system of attachment, to the bottom of the spring as
it sits on the perch shall be the same as stock.
d. Suspension geometry and range of travel shall not be
altered.
6. Brakes
a. Components
1. The make and material of brake pads and linings may be
changed.
2. Brake fluid may be substituted with any brake fluid.
3. Brake rotor dust shields may be removed.
4. Flexible rubber brake lines may be replaced with Teflon
lined, metal braided hoses.
5. Any brake ducts are permitted, but they must serve no
other purpose and must mount without modification to
other components, but front parking light assemblies may
be removed to provide an opening for the ducts. The
ducting must not be visible from outside the car.
6. Stock replacement brake rotors may be obtained from
sources other than the manufacturer provided they are the
exact equivalent of the stock rotors.
7. Wheels and Tires
a. Wheels
1. Any type wheel suitable for competition may be used,
provided:
a. Any wheel not exceeding the specified diameter and
rim width on the vehicle’s specification line may be
used.
b. Wheels are permitted any offset provided the tire tread
(that portion of the tire that contacts the ground) does
not protrude beyond the fender opening when viewed
from the top perpendicular to the ground, unless specified differently on the individual spec line for that car.
To determine compliance the vehicle should be rolled
through a powdered substance, as raced with driver,
in order to indicate the tire tread contact patch under
static conditions.
c. Cars equipped with lug bolts may convert to wheel
studs and lug nuts.
d. Wheel studs may be replaced with longer studs as
necessary to fit optional wheels. Wheel spacers may
be used for purposes of adjusting track.
2. Hub caps and wheel trim rings shall be removed from all
wheels.
b. Tires
Unless otherwise so noted on a vehicle’s TCS line, all cars shall run GCR - 659
TCS
the tire size as listed for the vehicle in the TCS or an authorized
replacement size. When authorized replacement tires are used, the
same size tire shall be used on each axle (front tires need not be
the same size as rear tires).
Tires must conform to 9.3.45. All tires shall be offered for sale over
the counter through the manufacturer’s tire dealer network. The
brand of tire and tire pressures are unrestricted.
All cars shall run tires with a minimum of a “U” speed rating. For
size determination, the molded section shall be used. All cars are
allowed a section increase or decrease of 10mm or 20mm (e.g.,
195 may use 175, 185, 195, 205 or 215). All cars are allowed an
aspect ratio increase or decrease of 5 or 10 (e.g., 55 may use 45,
50, 60 or 65).
8. Body/Structure
a. Configuration/Modifications
1. Component Alignment: All body components shall maintain their original relationships. Gaps or openings shall not
be increased, decreased, or eliminated through realignment of components. Normally occurring gaps or seams
shall not be taped over.
2. Door Glass
a. All cars shall run with both front door windows fully
open (down).
3. Spoilers (Wings)
a. Only original equipment front spoilers, dams, and rear
spoilers and wings shall be permitted unless specified
on the vehicle specification line.
4. Other Body Components
a. Sunroofs, Targa tops, and T-tops are only permitted if
installed by the manufacturer of the vehicle. If installed
they must be retained on the vehicle, run in the closed
position, and securely bolted in place unless the operating rails adequately secure the panel. Glass panels
are permitted.
Hardtops: If a hardtop is required, it shall be the original equipment hardtop from the vehicle manufacturer
unless an alternate part number or manufactrer is
listed on the vehicle spec line.
b. Hatchback “privacy covers” shall be completely
removed.
b. Appearance
1. Cars may be painted any color(s). Markings and numbers
may be painted.
2. Vehicles shall be neat and clean, and shall not be dirty
externally or in the engine or passenger compartments.
They shall not show bodywork damage, and shall not be
presented for competition totally or partially in primer.
Cars that do not bear the prescribed identification marks,
Club Racing logos, and numbers in conformance with GCR
Section 9.3 Identification Markings, shall not be approved
for competition.
9. Driver (Passenger) Compartment (Trunk)
a. SeatingGCR - 660
1. The driver’s seat (only) shall be replaced with a onepiece bucket-type race seat. Factory seat tracks/brackets
may be modified, reinforced, and/or removed to facilitate
replacement mountings provided they perform no other
function. All other seats may be removed.
2. Rear heating/air conditioning ducts which are located
under the driver’s seat may be removed or modified to
facilitate seat installation.
b. Steering Wheel
1. Aftermarket steering wheels, and their required mounting
modifications, are permitted.
c. Gauges and Accessories
1. Water temperature, oil temperature, oil pressure, and
boost/vacuum gauges are permitted and shall be securely
mounted, and shall perform no other function other than
their primary use.
2. Interior mirror(s) may be replaced with a multi-panel type
mirror, but no such mirror shall extend beyond the confines
of the interior of the vehicle.
3. Two-way radios may be used.
4. Hand controls are permitted in those instances where the
driver can demonstrate the physical need for them.
5. Data Acquisition Systems
Stand alone data acquisition systems are allowed to
be in use in the car during practice, qualifying and race
events. These devices may be connected to the data link
connector in the car to extract available data. This must be
a one-way out connection and no calibrating or alteration
of the PCM is to be done while the car is in motion and the
system in place.
d. Interior Modifications
1. Front passenger seat, rear seat back, rear seat bottom
cushion(s), sun visors, seat belts and their attaching
hard¬ware and bracketry may be removed. In any automobile where allowed removal of rear seats, upholstery,
etc., creates an opening between the driver/passenger
compartment and an exposed gas tank, fuel cell, or part
thereof, a metal bulkhead which completely fills such
opening shall be installed (See GCR 9.3 Fuel Cell Specifications).
2. Carpets, carpet padding, center consoles, floor mats, headliners, sun roof liner and frame, dome lights, grab handles,
and their insulating, attaching or operating mechanisms
may be removed.
3. Any removable covers used to cover spare tires, tools,
bins, etc., may be removed along with attaching hardware
and bracketry.
4. Removal of radio and speaker components is permitted.
5. All other interior trim panels, except the dashboard, may
be removed. Other than to provide for the installation of
required safety equipment or other authorized modifications, no other driver/passenger compartment alterations
or gutting are permitted.GCR - 661
TCS
6. Removal of radio and speaker components is permitted.
10. Safety
a. Steering Column (Locks)
1. Steering column locks may be removed or disabled.
b. Safety Harness
1. All cars shall be equipped with a driver’s restraint system
meeting the specifications of GCR Section 9.3 Driver’s
Restraint System.
2. All cars shall have a driver’s side window safety net
complying with GCR Section 9.3 Window Safety Nets
shall be mounted in such a manner as to provide protection in the event the driver’s door opens.
3. In those cars where a window safety net cannot be
installed, arm restraints shall be used. Arm restraints are
not an acceptable substitute for window nets in any other
type of car.
c. Fire Systems (Extinguishers)
All cars shall have, as a minimum, a fire extinguisher meeting the
specifications of GCR Section 9.3 Fire System. Touring Category
automobiles may be equipped with a fire system meeting the specifications of GCR Section 9.3 Fire System.
d. Passive Restraint Systems
Passive restraint systems shall be deactivated. Air bag systems
shall be deactivated and may be removed. If the car is to be used
on public roads, we recommend that these items be reactivated/
rearmed/replaced when not in competition.
If so equipped, the rolling door lock mechanism may be deactivated
by unplugging the components.
e. Towing Eyes
Towing eyes per GCR Section 9.3 Towing Eyes, shall be fitted.
f. Electrical Master Switch
An electrical master switch may be installed.
E. Car Classification
These classifications shall be reviewed on an annual basis, and shall be
effective as of January 1. Once these classifications have been officially
published, no changes or additions shall be made after March 1 of the
calendar year.
Touring Category Classes are as follows: T1, T2, T3, and ST.
1. Weight
a. The weight, as listed on an automobile’s Specification Line,
shall be with driver and required ballast. Refer to GCR Section
9.3 Weight. If a cool suit system is utilized, it shall be weighed
with the car as it came off the track.
2. Ballast
a. Some vehicles may be required to carry specific amounts of
ballast. If such ballast is specified for an automobile, in addition
to the requirements of GCR Section 9.3 Ballast, the following
requirements shall also be met:
1. All specified ballast shall be securely mounted in the
passenger footwell of the vehicle, aft of the firewall and
any footwell angle, and forward of the passenger seat GCR - 662
unless otherwise so permitted on the vehicle’s TC Specification Line.
2. It shall be in segments no lighter than ten (10) pounds and
no heavier than fifty (50) pounds, and shall be capable of
being weighed apart from the vehicle.
3. Each segment shall be fastened with a minimum of two
(2) one-half (1/2) inch bolts and positive lock nuts of SAE
Grade 5 or better, and shall utilize large-diameter, loaddistributing washers.
4. Holes may be drilled in the passenger footwell floorpan for
purposes of mounting the ballast (only), and said floorpan
may be reinforced as required for the same purpose.
Share this post
Link to post
l30thelion
When I asked the question I knew I might not like the answer....it's great to have a goal to strive for. I'm sure those T2 guys are serious drivers and know a lot more about setup than many of us.
Why do you prefer running SCCA? Seems the rules are written to pick winners. Aren't there cars that are given huge unfair advantages/allowences before even being on track (subaru/solstice/mustang)? At least the NASA points system is the same for all cars (ok, I know s2ks get screwed some and other cars also...system is not perfect) but in general you don't have to buy THE CAR to have for that year to have a chance. The points system allows for so many ways to skin a cat (like the Honda Sedan you mentioned).
If NASA had NATIONAL events throughout the year, the level of competition would be different. You can't really compare regional TT events w/ SCCA NAtional Events or event SCCA Tours/Pro Solos.
Share this post
Link to post
Balroks
Ya I agree agree agree times were slow besides Gates, as Gates car had broken records at almost every track it ran because it's got a gazillion dollars in it, sucks he didn't get to post official times. Tis why I said if you or Jimmy jumped in to any of those Street or Modified cars you'd find several seconds above the guys who've never ran Sebring before. Also didn't say Marty is cheating, he's very well documented, just saying what you posted beforehand didn't have everything.
Share this post
Link to post
TurboShortBus
I have been told that there is a huge SCCA presence in the Central Florida area, so it shouldn't be to hard to find somebody to come out and play, right?
Mark
Share this post
Link to post
Balroks
Pretty much what I see as well. Several years ago it was the Evo, then GM dumped a whole bunch of cash to debut the Solstice which was half a lap ahead of people at the 09 or 08 runoffs, now Ford has stepped in an dumped a huge amount on the 302 which nobody was touching until it rained and Marty used rain tires and came from 5th to reel him in. Ford will likely dominate 2012 it's anyone's guess for 2013.
Share this post
Link to post
Mrsideways
Mark, They have 250 to 300 cars show up for a Regional Race. But they are all IT cars. IT cars have NO place to play in NASA cause a FAST IT car is a mid 80's Rx7 with 150whp. Pts wise it goes to TTA they won't show up cause they've got no shot.
BTW they run low 30's with that 150whp.
At the same time an SCCA National Event brings the same number of cars here in Florida but not from the same crowd. The IT guys are given STU and STL to run it but they are so out classed they don't show. National Event draws cars from all over the country.
I like running SCCA cause I feel like a Win means more at a National Event. Regionals don't have the same feel, wins are far easier and I rarely get more then a couple cars in my class so I use those as test weekends. Last years January National at Sebring I had almost 30 cars in my class in STU.
Share this post
Link to post
TurboShortBus
So, what you're saying is that, while the SCCA IT cars have weight/power ratios closer to TTD or TTC cars, they rack up a ton of NASA TT/PT modification points in all other categories (tires, drivetrain, suspension, brakes/chassis, aero, cage), right?
Mark
Share this post
Link to post
Mrsideways
Mark
More like P/w Weight of TTF. But yeah. Like the protege is 110whp and 2640lbs race weight. Has to run a 6 inch wide wheel.
So tiny tire, No power, not all that light. SCCA class ITB. Chi I think ran a low 2:43 in it.
NASA Classing It's TTF at 2385lbs
TTF is 19.5:1
Protege actual is 24:1
But the protege takes points for
Springs
Shocks
Sway bars
Header
Exhaust
205 tires
Air Dam
Valve job
Compression
Stand alone ECU.
Air intake
Thats 37 points so it ends up in TTE with a Power to weight no where near close to TTF
When Chi's car was broken I kept telling him to bring out the protege and he kept saying no... he'll get killed in it. Mark that's why they don't show up.
Share this post
Link to post
BlkGt3
I like NASA classing system much better than SCCA as it allows the car owner to decide what is important. As for S2000's getting screwed I don't see how. You pick your car and learn to live with the Warts. I happen to like M3's so I drive one, can it be a good TTC car yes, am I a good enough driver, not yet but someday maybe. I am the 2011 Florida NASA TTC champion, even though you are a better driver, as I attended more events and with the FL NASA scoring system attendance counts.
This is for Mark for the future TT should allow a driver to drop 4 events and still be eligible for the championship ie if we have 8 race weekends=16 events you would only count the top 12 events.
Now a typical Regional CFR SCCA race weekend @ Sebring has over 200 entry's and Daytona usually runs over 300. NASA has what 30 to 40 race entries so why would you race NASA in a 1 or 2 car class when you can run in 5 to 20 car classes.
TT is a different story as SCCA does not have a viable TT program because it is run by the racers and not user friendly. Yes Ian,Chi, Jeff, Josh, myself are trying to get more TT attendance from AutoX but it is slow going with cost being an issue and worries about car damage, should not be an issue unless you drive an S2K Maggie and Nick are working their way through the ranks and should get there soon. Oh wait did I just name 7 AutoX who now TT or are working on getting there.
Peter
Share this post
Link to post
TurboShortBus
Mark
TTF is 19.5:1
Springs
Shocks
Sway bars
*Header
*Exhaust
205 tires
Air Dam
*Valve job
*Compression
*Stand alone ECU.
*Air intake
I was going by your example of mid-'80s RX7s having 150 rwhp, and assuming 2200 lbs race weight. No other cars were mentioned.
You do realize that a base reclass for the Protege that you mentioned above will be more accurate and conserve many of the engine-related modification points, right? I noted them with an asterisk. The provisions are already in place in the TT rules for this car to be more accurately classed. As you have had your own cars re-classed based on weight and power, I can assume that you already know that this could help Chi's Protege, but the choice was made not to do it. If that's why they don't show up, then they can't be helped, can they?
Mark
Share this post
Link to post
TurboShortBus
Please forward this to Greg Greenbaum via email ([email protected]), as he is taking suggestions for the 2012 TT rules.
Mark
Share this post
Link to post
