jaje Posted November 21, 2011 Share Posted November 21, 2011 Wonder what the general consensus on: - removal of engine emissions equipment (we can remove the cat but there's a lot of emissions stuff such as charcoal canister, vacuum lines, etc.) - headlights - can we remove the motor mechanism and built a manual setup to set to full open / full close? - a/c equipment - can we remove the condensor / evaporator / compressor / all lines (does not specifically say we can or cannot) - remove power steering pump (says we can defeat the rack but not that we can remove these items). I don't have access to cars or what I can confirm as spec legal engine bay item removal / modifications Quote Link to comment Share on other sites More sharing options...
Ole Posted December 3, 2011 Share Posted December 3, 2011 Wonder what the general consensus on:- removal of engine emissions equipment (we can remove the cat but there's a lot of emissions stuff such as charcoal canister, vacuum lines, etc.) - headlights - can we remove the motor mechanism and built a manual setup to set to full open / full close? - a/c equipment - can we remove the condensor / evaporator / compressor / all lines (does not specifically say we can or cannot) - remove power steering pump (says we can defeat the rack but not that we can remove these items). I don't have access to cars or what I can confirm as spec legal engine bay item removal / modifications Genarally: If it doesn't say you can, then you can't. However, I will tell you that the Vac Canister needs to be there as well as vacuum lines. Can't mess with headlight motors. A/C equip you list can be removed, leave heater core intact but you can re-route hoses (I left mine connected for rain races). PS pump can be removed (make sure you install a bolt in one of the mounting holes or you will pump out oil). Regards, Alan Quote Link to comment Share on other sites More sharing options...
jaje Posted December 3, 2011 Author Share Posted December 3, 2011 Thanks Alan. I am getting the plugs that advanced auto sells for the p/s rack. I'll leave in the headlight motors and maybe the heater lines as well in order to defog the windows in rain races. Quote Link to comment Share on other sites More sharing options...
jaje Posted December 16, 2011 Author Share Posted December 16, 2011 I removed the dash and inside it has a crossmember - is that removable or must it be kept? I was planning on doing cage bar behind the dash if I could (did this with my previous racecar - 944) as it is integral to the rollcage. The general rule says dash may not be modified. Quote Link to comment Share on other sites More sharing options...
