FS: Chase Cam PDR100 + SS1000 Complete 2 Camera System
Posted (edited)
UNIT IS SOLD....
Full 2 camera ChaseCam system. Includes 3 camera clamp mounts, 2 cameras, and everything listed with the PDR100 and SS1000. Connects to Traqmate Data system with added cable (included). Also includes stacking bracket system from ChaseCam - everything you need.
PDR100 Solid State Video Recorder
BulletCam System, 560+ lines, Wide Dynamic Range
3 Camera Mounts
4GB Compact Flash Card
5' Mini DIN camera extension cable
Cigarette Lighter Adapters
MiniAV adapter cable
SS1000 Video Processor
This is a great little PIP box from chasecam. It is the same shape, size and build quality as the PDR100 mpeg2 recorder. It has two video inputs which can be configured by the user to make many different combinations of pictures within picture.
The inset picture can be top left/right or botton left/right. You can also split the screen horizontally or vertically.
Asking $795 for all
If one camera is removed, the ss1000 will default to full screen display for the connected camera.
The ss1000 will provide power for the two cameras using the miniDIN to standard bullet camera connectors supplied.
To connect the ss1000 to the pdr100 you should use the miniDIN to miniDIN cable supplied with this unit.
  • 3 months later...
  • 4 weeks later...
