2004 Cadillac CTS-V
Posted (edited)
Car is a 2004 Cadillac CTS-v race car in Black. Car was originally built by Phoenix Racing and sat on the pole for the 2004 Runoffs at Mid Ohio. This is the most fun race car I have driven in the past 25 years. The Cadillac CTS-V is currently set up to run NASA Performance Touring B or SCCA T2. Listed below are the various components currently installed on the car or spares to be sold with the package. Car has clear title in my name.
ENGINE
GM LS-6 5.7 litre engine
GM spec 400 hp / 390 torque (never had on dyno)
Davis radiator
GM 25534461 Engine oil cooling kit
Royal Purple synthetic oil
Custom ECU mapping
Custom 2.5” exhaust
Cats removed
DRIVE TRAIN
GM OEM limited slip differential
GM 25534463 T2 spec differential cooling kit
Tremec 6 speed transmission
GM 25534462 T2 spec transmission cooling kit
GM OEM traction control
Royal Purple synthetic fluids
SUSPENSION
GM OEM front shocks
GM 25534467 T2 spec front springs
GM 25534469 T2 spec front sway bar
GM OEM rear shocks
GM 25534468 T2 spec rear springs
GM 25534471 T2 spec rear sway bar
BRAKES
Factory ABS
Front OEM CTS-V calipers
Front OEM spec rotors
Rear OEM CTS-V calipers
Rear OEM spec rotors Spare factory rotors
GM 25534464 brake cooling kit
Spare factory calipers
Spare factory shocks
Spare front hubs
Spare front knuckles
Approved tow eyes
INTERIOR
NASA and SCCA approved roll cage by Phoenix Racing
FIA approved roll bar padding
Cobra composite race seat
Gutted interior to minimize weight
Simpson window net
Simpson 5 point racing belts
Fire extinguisher
Longacre 14” Convex mirror
OEM passenger seat (not installed) for track events
WHEELS / TIRES
12 18” X 9.5” wheels aluminum wheels
BFG R1 275 X 35 X 18 tires (4 new / 4 good used)
Priced at $18,000. For additional information or photos please contact Rob Jones at rjncj82 AT yahoo.com or call at 417-468-1082.
Do you have any spare parts that your looking to sell separately ???
Unfortunately my V just went to Phoenix to get converted...
  • 2 months later...
Sorry Junior1. We will keep everything as a package.
For NASA PTB, the spec weight with driver is 3847 lbs. Obviously you use the points as you see fit. The bare car (without driver) could be taken down to as low as 3450 lbs or even lower and add back the weight as needed. The car would be the ultimate car for a larger person wanting to be competitive.
