xtnct Posted December 30, 2011 Posted December 30, 2011 Used front stock Brembo pads from an EVO VIII. These pads will fit EVO IX & X Brembo calipers. According to some posts on the internet, this shape apparently is also used by the STI, Ford Mustang Cobra/Shelby Brembo, Caddy CTS-V, Volvo S40, Genesis and Camaro SS. Here is the link I found but do your own research: http://www.iwsti.com/forums/gr-braking/229076-evo-aftermarket-pads-my-sti.html They are over 13mm thick with the backing plate (which is about 5mm) so that leaves ~8mm of pad thickness (for reference, new pads are 10mm thick). In other words, there is 80% of pad left on them. There is some rust on them from having sat outside for a little so you'll just need to run a few swipes with some sandpaper before you install them. $120 shipped continental US. Quote
