Adam Ginsberg Posted January 3, 2012 Posted January 3, 2012 All this equipment came from a fully running, late 80's Ford LTD ('87, '88, or '89...not 100% sure). I am COMPLETELY certain, however, that it had a ROLLER CAM setup from the factory, as the engine was torn down. Everything is USED, unless noted otherwise. What you see is: Stock 5.0L upper and lower EFI intake Stock TB and EGR spacer Stock coolant crossover tube Stock fuel rails with 19lb/hr injectors Stock wiring harness - it has the injector harness, ECU harness, and several other harnesses (alt, smog, etc). All in good shape Stock roller cam EFI distributor Stock ECU (not an A9L) GZC23 is marked on the case Stock smog pump Several brackets Other assorted goodies EVERYTHING IN THE PICS IS INCLUDED, pricing includes shipping to any location in the CONUS (a bargain, given the weight of all this gear). I'm not interested in separating anything - it all goes together. It's already packed in 3 boxes, ready to go. $125 - a damn good deal. The shipping alone will cost ~$40-$50. It will stay listed here until 8am, 6 Jan 2012. If not sold by then, it goes to ebay. I want this shit out of my garage, and in the home of someone who will put it to good use. Great to use for a rod project, or convert some other old SBF (Falcon, Fairlane, Bronco, Mustang, etc). PM here, or email Quote
