Rick D Posted January 8, 2012 Posted January 8, 2012 (edited) Factory Five Roadster (Spec Racer or Challenge Car) Specifications Factory Five chassis number SP5270 Owner/Builder Rick Davis (804) 932-9612 or [email protected] Weight 2250 lbs Weight distribution 46.2%/53.8% Wheel base 90 in. Overall length 158 in. Front track 58.8 in. Overall height 47 in. Overall width 70.5 in. Ground clearance 3.5 in. Fuel capacity 22 gallons Kit assembled by owner during 2004-2005 Body painted by Woods Auto Painting Standard Specifications for the Kit include: Construction Layout Front/mid engine RWD Roadster Frame Tubular space frame with integrated backbone Roll cage NASA Approved 1.5 inch DOM Tubing Sub-structure Aluminum panels riveted and bonded to frame Suspension Front suspension Independent double arm Rear suspension Solid rear axle with three link and a panhard rod Shocks/springs Coil over ride height adjustment Steering Manual – Flaming River Rack Brakes Vented 13.1 inch disc front & 11.6 inch disc brakes Wheels 1 set, steel wheels from Cobra Mustang 4 lug 17in. Street tires – 255/45 ZR GForce T/A’s Street Tread 1 set steel wheels from Cobra Mustang, 4 lug 17 in. Track tires – 275/40 Kuhmo Ecsta Titled with DMV 4/28/06 as specially constructed vehicle Current car is street legal with inspection to - 7/12 Current mileage approximately 1,300 miles Options added by owner – 1988 Mustang GT 5.0 High Output engine Donor car had a salvaged engine which a is a Jasper rebuild with less than 6,000 miles when car was totaled. Stock Horsepower rating 225 with 300 ft lbs of torque Mustang rear end with traction lok and 3.27:1 ratio Fire suppression system – for cockpit and engine compartment Removable windshield and installed windshield wipers2 Brake proportioning valve—Willwood Engineering1 Rear disc brake kit with stainless braded brake lines Steel braided lines from engine to fuel cell Canton road racing oil pan Mcloed Steel bell housing Oil cooler in lower grill Car has been used in driving school at VIR and Summit Point and for local pleasure driving-- weather permitting Price $19,500 Will consider trade for Triumph TR6 Edited January 14, 2012 by Guest Quote
clubracer6 Posted January 9, 2012 Posted January 9, 2012 Could you please provide a location and price? Quote
