bluebandit48 Posted January 9, 2012 Posted January 9, 2012 I have a set of coil over struts, These work on mustangs from 87 to 04. They are a perfect match for 87 to 93. They will work from 94 to 04, if the car is lowered, which is what the coil overs are for. They are in OK shape. they have been used and they need carry over hardware. They are 5 way adjustable for rebound and compression. This is a great setup if you want to lower the front of your car and drop some LBS from the stock stuff. The shocks new are about 150 a piece and the coil over setup is about 250 new just for the coil over kit and no springs! I am including the springs! I believe the spring rate is 325 it is hard to see the engraving. It is a Hypercoil. They are curently on ebay. http://www.ebay.com/itm/120840599956?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649 Also Maximum Motorsports adjustable rear control arms for a mustang 79-98. these are on ebay as well. http://www.ebay.com/itm/120840580259?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649 Quote
bens98gt Posted January 10, 2012 Posted January 10, 2012 What are you asking for all of it? and what are spring rates for the front and back? What kind of shocks and struts are they? Quote
bluebandit48 Posted January 10, 2012 Author Posted January 10, 2012 Rear Control Arms just Sold.. Front struts and springs only no rear shocks or springs spring rate is 325 I believe. The engraving is so light it is hard to tell. They are tokico illuminas. part number BB3026 looking to get about 350 for the struts and coil over package. Quote
