MartinD Posted January 30, 2012 Posted January 30, 2012 Hey guys, Trying to help sell this for a close friend. If you know anyone that may be interested please inquire: [email protected] Doc Hill’s Special 525 / M3 HPDE Track and Street Legal Asking...$15,000 Besides being acceptable as a “daily driver”, this is an excellent HPDE car. (I drive it to and from the track.) Suspension which provides very good handling, an E36 M3 package delivering surprising power to weight performance which makes it move down the track, and equally important, it has brakes (M5) that mean business. Marry this to the BF Goodrich G Force R1 tires, and you have a wonderful car. Great for the beginner, or seasoned vet. I have kept it in as good condition as I possibly can. Korman BMW frequently inspects and fulfills all maintenance as required. E36 M3 Korman Stage 2 Motor, 280 HP BMW M Sport Group N Cams, custom computer chip, M3 wire harness and computer, multi-angle valve seat work, ported, polished, lightened, balance connecting rods. Korman oil system mods to increase oil flow through rod bearings. Aluminum thermostat housing, cooler thermostat, K&N filter. Injectors cleaned and calibrated, with new BMW cylinder head, valves, valve springs, hydraulic lifters, cam housing, Vanos unit, etc. New belt tension rollers, belts, hoses and stainless steel headers. Total engine: $13,900 M3 twin mass flywheel w/new H.D. clutch plate, disc, release bearing (Alum flywheel Jan 07) New Cam pulse generator, 02 sensor and idle valve Supersprint free-flow exhaust Suspension Korman Roadsport Suspension Package, w/Bilstein sport shocks, springs, front and rear anti sway bars and bushings. Driving school special race suspension conversion, includes Front 2.5 dia progressive tender spring coil over assembly, with Threaded aluminum sleeves for adjustable ride height Rear 60mm dia progressive tender spring coil over assembly. Custom valved Bilstein shocks Adjustable front camber plate assembly Adjustable front sway bar link Corner weights, camber, toe adjustments Total suspension: $7,795 Differential 50% limited slip conversion with full diff rebuild and 3.64 gear set Total: $2,290 Wheels & Tires Ronal 3 pc lt wt SX 17x8 wheels Ronal 1 pc lt wt LV 17x8 wheels Michelin Pilot PS2 245/40ZR17 (Street) BFGoodrich G Force R1 Tires 245/40/17 (Track) Computer mount and balance – 8 wheels/tires Total Wheels & Tires: $6,184 Brakes ATE Super Blue Fluid, flush and bleed M5 Front Calipers and Rotors Brake intake ducts & three inch hoses Hawk Gold HT 10 Race Pads, Front & Rear Ferodo Front & Rear Street Pads Slotted rear discs Stainless Steel Clad Brake Lines Total Brakes: $3,873 Recent Maintenance and Performance Items (2008-11) Rear suspension Pitman arms Front and Rear new wheel bearings Clutch slave cylinder Steering track rod joints H.D. Front Thrust Rod Bushings Aluminum Flywheel Conversion Sachs Clutch plate and disc New Guibo New Fan Clutch, water pump ring New Fan, rad cap New Sparco 4 pt Sport Harness New front M5 Rotors (Feb 10) New Hawk H10 race pads (Feb 11) Bilstein Shock rebuild 2011 Season Refresh $5,817 (Does not include normal maint.) Total spent building and maintaining the car: $48,203 (plus cost of car) Cost breakdown of improvements: Korman built E36 M3 engine (280 HP) Related power train items Suspension Differential Wheels & Tires Brakes Season Refresh 2011 Recent Maintenance & Performance Total cost of improvements (plus cost of car): 13,900 2,810 7,795 2,290 6,184 3,873 5817 5,534 $48,203 Car will be at VIR with Tarheel BMW in February – happy to take you for a ride with me if not sold by then. Quote
von_zoom Posted February 6, 2012 Posted February 6, 2012 Here are two photos of the engine. Sorry they were not included with the above. FYI, I will be at VIR for the Tarheel event, and if anyone interested is there, please look me up and I will be happy to take you for a ride. Many photos are available - please feel free to pm or email me at [email protected] vz http:// http:// Quote
von_zoom Posted February 9, 2012 Posted February 9, 2012 Several have request additional photos, thus are here. Anyone who is interested, and will be at VIR, please let me know and I will see if I can be there so you can see the car, and perhaps let me take you around the track. pm or email at [email protected] vz http:// http:// http:// http:// Quote
brkntrxn Posted February 9, 2012 Posted February 9, 2012 As if it matters, I will vouche for Doc and his car. He has run quite a few events that I worked (THSCC, Asphalt Ventures, etc.). Great guy! -Kevin Quote
von_zoom Posted February 12, 2012 Posted February 12, 2012 Thanks Kevin. The car will make a good entry into HPDE for a new driver, quick, but forgiving to drive, and can easily double as a DD. It was built by Ray Korman as his personal car, and has been featured in BMW magazines. As with Ray, it has a lot history behind it. Hope to see you at VIR soon. I have a full schedule ahead of me, so will be busy at VIR. A photo (Oak Tree) from VIR years past. Note air under right tires, but very little lean under weight transfer. vz http:// Quote
