vwmann1 Posted February 7, 2012 Share Posted February 7, 2012 (edited) We have decided to go GTS racing and so all the Spec parts I have laying around have got to go. Here is a list of the things I have and what I will sell them for: Engine: • long block with 88 pistons, new rings, main and rod bearings, con rods with new wrist pin bushings and nuts, std cross drilled crank, and new reconditioned head w/ 3 angle vale job and new valve guides:$600 slod • 3 full sets of con rods with new wrist pin bushings: $60/ set • two heads, 1 new reconditioned w/ three angle valve job and new guides. 1 used 3 hrs after reconditioned: $175 new, $100 used sold • three sets of late headers: $30/set 3 sold • std crank not cross drilled: $75 sold • two intake mani : $20/ • flywheel: make offer • 6 cams: make offer • 2 cam towers: make offer • box of low comp pistons: make offer Suspension: • one set 350 lbs Hyperco springs$40 sold • one Koni front shock insert new late offset: $40 • pair Koni rear shocks used good condition, not leaking $40 • two sets late offset phone dials, one set black one set silver: $80/set silver sold, black pending • one set RA1 wets $100 sold Drive train: • two torque tubes one good one OK: good $50 OK $20 • QK code trans (short 5th) no LSD: $200 sold • 5P code trans (tall 5th) no LSD: $150 sold • rebuildable brake calipers: make offer UPDATE: complete oil cooler set up off 86 turbo $150 Hawk blue rear pads brand new in box $75 If you want to stop by after karting this Saturday I will open the shop. Cash talks if you know what I mean. Edited February 24, 2012 by Guest Quote Link to comment Share on other sites More sharing options...
vwmann1 Posted February 7, 2012 Author Share Posted February 7, 2012 updating as things go. Check back often, Quote Link to comment Share on other sites More sharing options...
Sm00thindian Posted February 8, 2012 Share Posted February 8, 2012 I'm interested in late headers, and the ra-1's if your pending sales fall through. deadprez[dot]racing[at]gmail[dot]com Quote Link to comment Share on other sites More sharing options...
vwmann1 Posted February 14, 2012 Author Share Posted February 14, 2012 I'm interested in late headers, and the ra-1's if your pending sales fall through. deadprez[dot]racing[at]gmail[dot]com All sold sorry Quote Link to comment Share on other sites More sharing options...
vwmann1 Posted February 14, 2012 Author Share Posted February 14, 2012 see list added some stuff Quote Link to comment Share on other sites More sharing options...
944-Spec#94 Posted February 22, 2012 Share Posted February 22, 2012 Doug, Thanks. Parts arrived nicely packaged and just as described. Quote Link to comment Share on other sites More sharing options...
vwmann1 Posted February 24, 2012 Author Share Posted February 24, 2012 glad they went to a good home. Are you going to have enough time to get your car rebuilt for the next race? Quote Link to comment Share on other sites More sharing options...
944-Spec#94 Posted February 25, 2012 Share Posted February 25, 2012 glad they went to a good home. Are you going to have enough time to get your car rebuilt for the next race? Yes I should. I will be installing a head on sunday. I don't expect any problems. Quote Link to comment Share on other sites More sharing options...
Sterling Doc Posted February 26, 2012 Share Posted February 26, 2012 We closing in on 20 cars - great that this worked out to get Joe to the big event at Autoclub! Quote Link to comment Share on other sites More sharing options...
944-Spec#94 Posted February 27, 2012 Share Posted February 27, 2012 glad they went to a good home. Are you going to have enough time to get your car rebuilt for the next race? Head is on and the car is ready to go for the race next weekend. Thanks! Quote Link to comment Share on other sites More sharing options...
