A1 VW performance items
  • Members
Eurospec 8v solid lifter head with Neuspeed 272 cam, Autotech HD valve springs, 42mm X 35mm valves. Removed it from the race car to use as a spare. (had a bigger valve head built to use a P&P with a 306 cam and 42mm X 36mm valves) Cleaned it up and put it on the shelf as a spare that I never needed to reuse. Its been sitting for the last 6 years. Will need new studs, cam gear and id probably put in new valve stem seals just because its been sitting for so long. Valves are adjusted and ready to go.
Head is located in SoCal.
$1000 OBO. + shipping
7.5lb lightened 020 Flywheel. $150 (NOT THE SCALES)
Scirocco 2 Euro headlights. 1 highbeam has small hole in it. Needs adjusters. Comes with side markers and housing. $200
1 pair of Rear ONLY A1 H&R Ultra low coilovers. As seen, no springs, spring perches or hardware. $275
A1 chassis camber plates. Brand new spherical bearings. $180
Parts are located in Lakeside, CA. Any shipping at buyers expense. all prices are negotiable. Installation available, local only.
