Jones Posted February 15, 2012 Posted February 15, 2012 Spec E30 / 1987 325is / 117K miles / Columbia SC / $12,000.00 OBO Up for sale is my Spec E30 race car. I’ve had a blast racing Spec E30 over the past few years. With a new baby at home, racing time is limited. This car is capable of winning with the right driver as it sits right now. I’ve won 3 Spec E30 races in this car but I’m usually a mid pack driver. Car is ready to race, needs nothing but a new home! When I bought this car in 2005 it had 112K miles on it and $20K worth of receipts for parts and labor that I will pass along with the car. Way too much to list in this ad but I will highlight the main points below. Most of the money spent went toward maintenance items, getting the car in perfect mechanical shape. This car has been a dedicated track car since 2004. I built it into a Spec E30 in 2006. I ran one event in 2007, 4 events in 2008, 7 events in 2009, 6 events in 2010 and 2 events in 2011. Since I have owned this car, it has been trailered to and from the track only seeing track miles and has been garaged the whole time I’ve owned it. Car has zero rust anywhere. This is an extremely reliable, safe, fun and competitive race car. Here is a quick list of highlights about the car: General Maintenance and performance items: All new rocker arms in 2006 (broke one at an event, replaced all with upgraded parts) New Camshaft at the same time rockers were done New timing belt and tensioner 2006 New radiator/expansion tank/water pump/thermostat/ and all hoses – 2006 New vacuum lines 2006 Rebuilt 3.73 limited slip diff 2010 New clutch 2008 New wheel bearings 2010 New wheel studs all four corners, 2011 New Fuel Pump and Filter 2009 Finned Diff Cover Tranny fluid change 2010 Brake fluid flush 2011 Stainless brake lines All 4 calipers rebuilt 2009 Last oil change Feb 2011 (two events since then) 4 wheel alignment Jan 2012 New Poly Transmission mounts 2012 Crank scraper 2009 Skid plate 2009 Auto Solutions short shift kit Custom welded in roll cage by Competition Cages in 2006 Two Sparco EVO seats Two sets of VAC floor mounts 3 sets of 5 point harnesses (two sets are expired, one new for 2011) I/O Port Camera mount for the roll cage Cool Shirt system with 2 cool shirts (one XL and one L) Wink rear view mirror Quick release steering wheel adapter, MOMO 330mm steering wheel VDO gauges Water Temp/Oil Temp/ Oil Pressure Suspension wheels/tires: 3 sets of 15”X 7” wheels 2 sets of brand new RA1’s with two heat cycles on each set (1 set of tires is toast) Ireland Engineering sway bars and end links Ground control camber plates Bilstein Sport shocks / H&R race springs (Spec E30 set up) ECS 10mm wheel spacers all around Poly eccentric trailing arm bushings Poly rear sub frame bushings Poly Diff Mount / Tranny Mounts / Engine mounts Spares / items included: 1 New set of front PFC 01 brake pads 1 set of new front rotors 1 set of new rear rotors, 1 good used set 2 rear axles (used but in good condition) 3 Five Gallon VP racing fuel jugs 1 NIB rear wheel bearing 1 NIB center support bearing 1 set of new Sparco seat sliders 1 new oil filter, used cooling and vacuum hoses, 4 used ABS wheel sensors NIB front and rear factory sway bar end links, used idle air control valve 1 set used front calipers, 1 set used rear calipers, various relays, complete spare used fuse panel with fuses 1 used fuel pump and sender assembly, Spare front grill assembly (center and sides), spare oil cooler line 1 set of headlights and buckets, 1 used master cylinder, AC compressor and lines, 1 used MAF sensor and air box 1 set of brake ducts for front spoiler, 1 spare set of tail lights, 1 set of used distributor cap, rotor and wires. The car is located in Columbia SC. Please call or email for more information. I also have an 18’ open aluminum car hauler for sale as well if interested. Brian Jones beertech@gmail dot com 803-260-8995 Quote
Jones Posted March 6, 2012 Author Posted March 6, 2012 Haha, I can throw in a six pack of PBR and a hand full of BeerTech Koozies! Quote
hank24 Posted March 12, 2012 Posted March 12, 2012 I didnt get any beer but I did get some koozies. Thanks again Brian. I cant wait to get 380 out on the track. Quote
