noodlexyz Posted February 21, 2012 Posted February 21, 2012 Hey Gents, I know in NASA TT GA Hoosier/Conti slicks are okay for the 10 point tire scale along with the R6, R1, ect. Does the same hold true for GTS or do you have to take the adjusted weight/hp index for full slicks? Thank you, -Ryan Quote
JSG1901 Posted February 21, 2012 Posted February 21, 2012 Hi Ryan, The determination is made based on whether or not the tire is DOT approved. R6s are, for instance. DOT-approved tires will say it on the sidewall. Otherwise, you have to use the race tire ratio. Quote
noodlexyz Posted February 21, 2012 Author Posted February 21, 2012 Got it! Looks like I'll be trying to snag some DOT's. Conti/Hoosier slicks are not DOT rated. Thank you, -Ryan Quote
