Thekid29 Posted February 27, 2012 Posted February 27, 2012 Car: *1991 Nissan Sentra SER with Georgia title *Southern car with no rust or crash damage *NASA TTE 2012 Log Book *Current SCCA 2011 log book Engine: *Original US SR20 high port *Calico Coatings main and rod bearings with new rings installed July 2010 *Fresh 3 angle valve job, new guides, springs, and seals January 2012 *Custom Tri Y header with Vibrant collector and 2.5” exhaust *OEM ecu trimmed by SAFC *Innovate LC-1 standalone AFR *Dynolabs tuned with current sheets available *Canton oil cooler kit *Double row aluminum radiator *Only Mobil 1 Suspension: *Koni 8610’s single adjustable revalved by Koni North America *Ground Control Coilover kit with Eibach Springs *Ground Control front camber plates *Shigspeed pillow ball rear strut mounts *7/8” rear sway bar *Urethane bushings throughout suspension *Upper and lower front strut bars *Custom rod end bumpsteer kit * Alignment by Gran Turismo East *Cross weighted at Balanced Performance *Team Dynamics wheels 14x7 * Safety: *8 point roll cage with drivers side triple Nascar bars *Scroth Profi II-6 Hans belts good till end of 2013 *FIA Kevlar seat and back mounts *Simpson right side safety net *E.S.S. 2.3 liter AFFF fire system. 1 nozzle for driver, 1 nozzle for engine bay *Water temp, Oil temp, Oil pressure, Volts, Fuel pressure (under hood) *Ultra Lap Timer included History: *2010 SCCA TT ITA Champion *Won 7 of 8 NASA SE TT’s in 2011 *Nasa TTE Track record at Roebling Road 1:23 *Road Atlanta 1:46 *CMP 1:53 $6000 Atlanta, Georgia 404 374-6946 Quote
ILIKETODRIVE Posted February 27, 2012 Posted February 27, 2012 (edited) Edited April 3, 2012 by Guest Quote
