Yaz Posted May 12, 2005 Share Posted May 12, 2005 I have a 1998 Impreza RS, points for everything BUT motor swap is 27 I start in class F i swapped in a STOCK JDM sti motor. the motor is 2.0L VF37 turbo runs only 1 cat now in classing do i start in C with the US spec STI which is a 2.5 or do i start in E with the WRX which is also a 2.0? AND say i start in E i also add the 8 points for the motor swap? the way and friend and i figure it, i should start in E and also add points for "non OEM forced induction" since the VF37 is larger than the WRX TD04 Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted May 12, 2005 National Staff Share Posted May 12, 2005 This is going to be a complicated classification, and will require you to speak directly with your TT or NASA-X Director to make a decision on this. Additional info will be required, like how much hp and torque the engine will be putting out. This is clearly not just a 7 or 8 point motor swap. Quote Link to comment Share on other sites More sharing options...
