TECHNICAL BULLETIN--Rocker Panel Modif.--Side Exhaust 3-3-12
  • National Staff
TECHNICAL BULLETIN (3-3-12):
7.3 (1)(d.)--
The current wording:
Modification of the floor pan for purposes of exhaust clearance only is
permitted and will be assessed via a Modification Factor in the “Adjusted” Weight/Power Ratio.
Will be substituted with:
d) Modification of the floor pan for exhaust clearance only and/or rocker panel for side exit exhaust only are
7.4.2--
Change wording to:
the rocker panel for side exit exhaust only = -0.4
  • 4 months later...
Are rocker panels allowed to be modified for the installation of air jacks?
  • National Staff
Pete,
I would say that they are technically not permitted to go through the rocker panels per the current wording of the ST Rules. I have brought it up for discussion for a possible rule addendum to permit them.
  • 2 weeks later...
  • National Staff
Pete,
We are going to add the modification of rocker panels for the placement of air jacks to the ST Rules. It will be a legal modification without a Mod. Factor assessment.
Pete,
Excellent! Will this modification be made prior to nationals or should I try and file for a waiver?
  • National Staff
We can do it before Nationals.
