National Staff Greg G. Posted March 4, 2012 National Staff Share Posted March 4, 2012 TECHNICAL BULLETIN (3-3-12): 6.2.3(1)(d.)-- The current wording: Modification of the floor pan for purposes of exhaust clearance only is permitted and will be assessed via a Modification Factor in the “Adjusted” Weight/Power Ratio. Will be substituted with: d) Modification of the floor pan for exhaust clearance only and/or rocker panel for side exit exhaust only are permitted and will be assessed via a Modification Factor in the “Adjusted” Weight/Power Ratio. 6.2.5.-- Change wording to: Modification of the floor pan for exhaust clearance only and/or the rocker panel for side exit exhaust only = -0.4 Quote Link to comment Share on other sites More sharing options...
