aaronsti Posted March 8, 2012 Share Posted March 8, 2012 i see almost nobody wears them. but what do you think about neck/head restraints such as the hybrid in hpde. Quote Link to comment Share on other sites More sharing options...
brkntrxn Posted March 9, 2012 Share Posted March 9, 2012 It is never to early to think about safety. However, it was one of the last things I did. If you do not have full harnesses, then your only option are the Safety Solution (Simpson) versions that are self supportive and strap to you. Quote Link to comment Share on other sites More sharing options...
n80 Posted March 21, 2012 Share Posted March 21, 2012 I did a DE event at CMP this weekend and my instructor wore and recommended one of these: He said it is a safety device and helps with neck fatigue. I don't see many folks wearing these at all. Any thoughts on why I might need or want one? Quote Link to comment Share on other sites More sharing options...
Lucid Moments Posted March 21, 2012 Share Posted March 21, 2012 I have a harness and half cage in my DE car, and I wear a HANS device when I'm on track. Quote Link to comment Share on other sites More sharing options...
sperkins Posted March 22, 2012 Share Posted March 22, 2012 I remember putting off buying a Hans because "it was too expensive". Fact is now that I can't believe I ran on track for 2 years without one. Yeah it was expensive, but once the commitment was made to buy it and the money was spent, it was no big deal - it was more of a mental thing than anything. Things can happen in the blink of an eye. It's not worth the risk to run without one. http://www.sccaforums.com/forums/forumid/24/threadid/425669/scope/posts Quote Link to comment Share on other sites More sharing options...
Rob O Posted March 22, 2012 Share Posted March 22, 2012 I bought one after my 4th HPDE events and I knew I was going to keep tracking the car. While there are not a lot of people in HPDE with them, at least that I've notice, there are more than you think that do use them. Keep in mind for the Hans, it only works with a 5 or 6 point harness system. Quote Link to comment Share on other sites More sharing options...
jimbow Posted March 22, 2012 Share Posted March 22, 2012 I did a DE event at CMP this weekend and my instructor wore and recommended one of these: He said it is a safety device and helps with neck fatigue. I don't see many folks wearing these at all. Any thoughts on why I might need or want one? Heavy Helmet, plus head, plus lots of work keeping head straight = neck fatigue When I wore my helmet for hours my neck would hurt, I bought one of these and wore it. It helped with the neck fatigue, my new helmet is lighter and I don't get the fatigue anymore so I don't wear it. It is not a substitute for a HANS. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted March 22, 2012 Share Posted March 22, 2012 foam collars aren't going to do alot in an impact a real Head/Neck restraint will. Do some research, there are alot of options out there besides HANS each with upsides & downsides. Pick what makes the most sense with the rest of your seat/harness/cage/car/egress-path setups. Quote Link to comment Share on other sites More sharing options...
aaronsti Posted March 23, 2012 Author Share Posted March 23, 2012 i have a 4 point harness that meets the ccr rules. should i get the safety solutions pro rage, or should i get the necksgen restraint Quote Link to comment Share on other sites More sharing options...
beerkat Posted March 23, 2012 Share Posted March 23, 2012 i have a 4 point harness that meets the ccr rules. should i get the safety solutions pro rage, or should i get the necksgen restraint Certain 4 point harness are allowed if they meet the CCR. Although I think that NASA discourages their use. The other part of your post. You are the one wearing it so you need to pick what is most comfortable for you. Quote Link to comment Share on other sites More sharing options...
08Bullitt0572 Posted April 27, 2012 Share Posted April 27, 2012 I did a DE event at CMP this weekend and my instructor wore and recommended one of these: He said it is a safety device and helps with neck fatigue. I don't see many folks wearing these at all. Any thoughts on why I might need or want one? I had thought about getting one of these, but I am so tight in my car my helmet doesn't have far to move. My helmet is light so it does not fatigue me. If I roll the car a foam ring is not going to keep my fat arse from breaking my neck anyway. Quote Link to comment Share on other sites More sharing options...
beerkat Posted April 27, 2012 Share Posted April 27, 2012 I have a friend who wears one. I see a lot of go kart people wear them. My guess is wearing one is better than having nothing. Quote Link to comment Share on other sites More sharing options...
OHIO4DRTEG Posted April 27, 2012 Share Posted April 27, 2012 I got the Hybrid Pro from US Racegear (after 3 events) and love it. Two things I want from the track to enjoy myself and be as safe as possible. When you think about the one time investment to help save your life 700 to 1000 bucks seams nominal. Quote Link to comment Share on other sites More sharing options...
beerkat Posted April 28, 2012 Share Posted April 28, 2012 If you only have the OEM seat belt then you need to look at H&NR that are anchored to the body and do not depend entirely on a harness to hold them on. I wear a R3 that will work with the OEM belts. It has paid for itself already. Quote Link to comment Share on other sites More sharing options...
[email protected] Posted May 8, 2012 Share Posted May 8, 2012 When you decide you are committed to track events, you will want to consider adding proper seats, harnesses and a minimum of a roll bar, and budget for an SFI 38.1 head and neck restraint. HANS, Hybrid Pro, R3, Neckgen (formerly Defnder) are all good systems and have been tested and all have their own pros and cons. If you have the opportunity to try them on, then do so. I see people using the R3 with a standard 3 point seat belt, but no data has ever been released by the manufacturer showing that it was tested using stock seat belt so keep that in mind. Quote Link to comment Share on other sites More sharing options...
whoahstu Posted May 9, 2012 Share Posted May 9, 2012 I bought my DefNder from OG Racing and love it. My dad got one too. Fewer things are as reassuring as sitting in the paddock, ready to go out, and lightly bobbing your head to take up the slack in the tethers. I got mine because I never really read of fires or major problems with cabin structure injuries in HPDE; most injuries seemed to be head and neck related. Quote Link to comment Share on other sites More sharing options...
bukit Posted May 9, 2012 Share Posted May 9, 2012 I can't say enough about proper safety equipment. Anything can happen while on track and safety equipment is never something you should skimp on. I bought a HANS a couple of years ago and put it to the test 3 weeks ago at Roebling Road. I hit the wall nearly head-on at almost 100 mph. I walked away without a scratch. If I hadn't been wearing a HANS I'm not sure I'd be typing this. Quote Link to comment Share on other sites More sharing options...
