jerrytx Posted March 12, 2012 Posted March 12, 2012 (edited) Selling 4 17x10 wheels with 275/40/17 Hoosier R6 used tires that should still have plenty of life left, no purple edges. Will NOW separate wheels and tires. Will be at TWS for NASA on April 27-29 with NASATX if you want to pick them up. Was asking $1650, now $1500! Buy these! Wheels are located in Dallas/Fort Worth, zip is 76248. http://flic.kr/s/aHsjyy6zv9 Wheel Details: All 4 wheels are the same. I compared them a month ago to a set of 18x10 DForce that were +43ET and these were identical. I have since sold the Dforce wheels. If I measure the backspace with a set of calipers and straight edges and ruler I come up with 6 ¾” (6 and 25/32” to be exact) from the inside of the bead lip wall to the hub. Tire details: I took 4 measurements for each tire. I measured the outside dimple, the outside Hoosier R6 "tread line", the inside R6 "tread line", and the inside dimple, all measured in mm. Date Code is 4 digits, first two are week produced, last two are year produced. I have pics of a close up in the sun of all 4 tires, PM or Email me and I’ll send you the 2mb pics of each. Tire 1: Datecode 0310 Outside, Tread 1, Tread 2, Inside 4.7, 2.4, 1.4, 3 Tire 2: Datecode 0310 Outside, Tread 1, Tread 2, Inside 3.6, 2.2, 1.5, 2.7 Tire 3: Datecode 2211 Outside, Tread 1, Tread 2, Inside 2.4, 2.1, 1.9, 3.9 Tire 4: Datecode 5010 Outside, Tread 1, Tread 2, Inside 4.7, 2.6, 2.2, 3.2 Edited May 3, 2012 by Guest Quote
jerrytx Posted May 3, 2012 Author Posted May 3, 2012 Now updated the first post with everything ever asked about these wheels and or tires. Quote
jerrytx Posted May 11, 2012 Author Posted May 11, 2012 Now on Ebay with a low reserve. http://www.ebay.com/itm/300709177645?item=300709177645&viewitem=&vxp=mtr#ht_502wt_1344 Quote
jerrytx Posted May 17, 2012 Author Posted May 17, 2012 Reserve MET, these things could go for as little as $1000. Quote
