ILIKETODRIVE Posted March 15, 2012 Share Posted March 15, 2012 ok, "dude", besides a swap and a few minor mods, tell me what is the huge difference between them, and again if you read my post I said "basically". You can take a H4 CRX single cam vtec, change the cams and intake and voila you have a H2 car. So BASICALLY is the same car and you didn't even need a swap. That's what I meant by "basically", dude. That's one way to interpret the rules. Another way is to look at H4 and H2 seperately. For instance: If I am building an H4 car, I am going to pick which chassis I believe is best based on which engine I have to use. If I am building an H2 car, I am NOT going to take an H4 car and change a few mods to make it legal for H2. Instead, I would choose which engine and chassis combo I believe would be best and build it to the maximum extent of the rules. The way you present it is someone that is choosing to run a mid-pack H2 car. The way I present it is someone that wants to run up front in H2, regardless of cost. That, unfortunately, is racing. Once again... In HC, if I don't build it to the max of the rules that is my own fault. They are outlined for me to follow, depending on which engine/chassis I choose. If I choose to build a budget mid-pack car I know what to expect out of the car. I also know what to expect out of myself. I also know what the limits of the rules are. Therefore, I should not complain and tell everybody else to lower their whp to let me catch up. Quote Link to comment Share on other sites More sharing options...
JW Racing Posted March 15, 2012 Share Posted March 15, 2012 If I choose to build a budget mid-pack car I know what to expect out of the car. I also know what to expect out of myself. I also know what the limits of the rules are. Therefore, I should not complain and tell everybody else to lower their whp to let me catch up. You have a very valid and noted point which has been stated before by a few others in the private section. However, if you had this "mid-pack" car and it was built to the legal rules limit (which happened to meet the cap), would you not think that the rule committee made a small mistake in judgement of classing a particular setup while others uncapped have a larger HP to weight advantage? Or is it the fault of the person who chose that particular set-up, for choosing a set-up that has a dis-advantage uncapped? Some users do not like to use B series or some do not choose to use K series and so on, it would not be politically correct to force a racer to use a particular package if that is not what what is available to them, not what they want or doesn't make them happy swapping in. To fix this problem nationally HC made the cap, and recently So Cal has created the regional cap for So Cal only. When capped just about every engine and chassis combo has a pretty level playing field and I personally think it will be better for competition and create a tighter pack. To add, the cap regionally is a good thing if it is designated for the Nats as well, since one doesn't have to gamble and dial in a setup the week before the nats, they have all season to dial it in since it is a national requirement and thus should have a better head start on competition at the nationals who are chasing the tune or setup. If your region had the cap instilled I can see you guys getting bothered by the decision, however this does not apply to your region and I don't quite understand why many in your region are getting so upset at a decision made for a completely separate region. If you want to crossover to So Cal, you will have an advantage by exceeding the cap, is that not something you want? Most of the racers in your region got lapped or nearly by So Cal's best, now you will have a better chance to run closer to the front with your HP advantage. Now if HP and all out open rules is what one wishes to have then please revive H1 from the morgue as I hope to see it as popular as H2 one day again because I like H1 more than H2, but if it is just a HP advantage one wants in a particular class then one must not like close and competitive racing. Quote Link to comment Share on other sites More sharing options...
Leland Posted March 15, 2012 Share Posted March 15, 2012 ^lolhelicopter Quote Link to comment Share on other sites More sharing options...
Members Marcel D. Posted March 15, 2012 Members Share Posted March 15, 2012 ok, "dude", besides a swap and a few minor mods, tell me what is the huge difference between them, and again if you read my post I said "basically". You can take a H4 CRX single cam vtec, change the cams and intake and voila you have a H2 car. So BASICALLY is the same car and you didn't even need a swap. That's what I meant by "basically", dude. That's one way to interpret the rules. Another way is to look at H4 and H2 seperately. For instance: If I am building an H4 car, I am going to pick which chassis I believe is best based on which engine I have to use. If I am building an H2 car, I am NOT going to take an H4 car and change a few mods to make it legal for H2. Instead, I would choose which engine and chassis combo I believe would be best and build it to the maximum extent of the rules. The way you present it is someone that is choosing to run a mid-pack H2 car. The way I present it is someone that wants to run up front in H2, regardless of cost. That, unfortunately, is racing. Once again... In HC, if I don't build it to the max of the rules that is my own fault. They are outlined for me to follow, depending on which engine/chassis I choose. If I choose to build a budget mid-pack car I know what to expect out of the car. I also know what to expect out of myself. I also know what the limits of the rules are. Therefore, I should not complain and tell everybody else to lower their whp to let me catch up. Of course you have to look at it separate, that is why they are two different classes. Of course if you want to build a H2 car you will try to choose which combo you think should be the best. But if you already have a H4 car and you want to go H2 then you should be able to do that too. H2 is not and should not be a Jr. H1, There is way more differences between H1 and H2 than there is between H2 and H4 and the way I see it you want to build a legal H1 car for H2. Everybody is fixiated in the word "horsepower", and horsepower doesn't equal racing, there is way more variables than just horsepower. I still don't understand how if we have a cap we are going to spend more money, I don't see it sorry. I'm going to give you an example with no names and places so nobody feels like the shoe fits but here it is. I went to this event where there was a late model civic SI running what must be a K20a2 engine, and then there was a well developed legal and max to the rules crx. There was absolutely no comparison between the two cars. I don't know if it was driver or car but this is a comentary I heard from somebody close to the SI " that crx has to be illegal". So now the car that is well developed and I know for sure is legal was considered illegal, just because the other car got passed like he was standing still. I don't think that would have happened with a cap. I'm not trying to convince anybody , we are going to try here and see what happens, I might even have to bring a truck load of cement bags to start weighing down some cars, fill the trunk with bags to the rules . Anyway we will see what happens in April. Quote Link to comment Share on other sites More sharing options...
ILIKETODRIVE Posted March 15, 2012 Share Posted March 15, 2012 Of course you have to look at it separate, that is why they are two different classes. Of course if you want to build a H2 car you will try to choose which combo you think should be the best. But if you already have a H4 car and you want to go H2 then you should be able to do that too. Sure, you could do that...but the car would be outclassed by a built to the rules H2 car. Examples: You're going to keep the stock brakes that you are required to have in H4? You're going to keep the stock (for that engine) gear ratios that you are required to have in H4? You're just going to drop in a longblock and say, "I should be able to keep up with these H2 cars!" Not gonna happen. What about someone running a B18B-powered Integra in H4? Just dump 250lbs and you're all set for H2? Yeah, not. This is why I would rather convert my PTE car to an H4 car. All I have to do is swap in LS 1-5 gears and ballast up. If I want to COMPETE in H2 and not just run for fun as a back of the pack car, I would have to get another swap and parts allowed within the rules ($$$) or buy a whole bunch of parts allowed within the rules ($$). This has nothing to do with the whp cap BUT it does have to do with the fact that H4 and H2 are not just seperated by swaps...which kind of does have something to do with the whp cap. Quote Link to comment Share on other sites More sharing options...
JW Racing Posted March 15, 2012 Share Posted March 15, 2012 What about someone running a B18B-powered Integra in H4? Just dump 250lbs and you're all set for H2? Yeah, not. ...which kind of does have something to do with the whp cap. I like you! You have very valid points in most of your posts and though it side tracks from the thread topic, it is very well related to the caps, and a few of those points have been brought up by others in the forum before. Thus this topic just about requires it's own thread as not to interfere with the So Cal cap ruling topic we are in. The following is just my opinion in an adult discussion and I mean no offense to anyone here including the RC. I do wonder what racers think of this - Something that has not been mentioned too much, and ILIKETODRIVE brought that up in my mind, is the fact for some to convert class to class. For me H1 to H2 is so easy, I just swap my engine and rims and voila! However H4 to H2, you have to drop in alternative cams, or x engine, fancy shocks and big brakes to be competitive in H2. This is in fact the case and an H4 racer here in so cal witnessed that himself, he added a camshaft and milled head to his CRX and thought it would be fine. It was fast but not reliable. Now he runs a whole new engine and brake setup. What I have personally noticed is the cars that are allowed aftermarket manifolds and alternative camshafts and such and such, are the very cars that exceed the cap by a good amount. Now if engine A was not allowed alternative cams and Engine B was not allowed intake manifolds they would very well be at or near the cap as is the case with the H2 engine I use the K20A3, no cams or intake allowed, it reaches the cap perfectly when you add bolt-ons and mill the head and boo-ya that's that. Not a problem there and the RC nailed it. So I would imagine if other engines were compensated by weight and not camshafts and certain parts, that it would be just about the same as having a cap without the label of "cap". This would be the "H4 with a swap" that some here are discussing and that would be the way H2 should be so it is easier for H4 to convert and so on. But building a Jr H1 class and now capping it to quell the unhappiness amongst certain drivers, shows that some of the aftermarket parts just may be a mistake. What this mistake should do in a positive way however is encourage classes like H4 and H1 to grow instead of everyone gunning to be in H2 and the other classes dying away, but it has not. Though this is just a theory and I can not say this is the way the committee thinks when the rules are made. Over the last few years I have built several competitors engines, be it a B or K or what not. I have taken them to the dyno be it dynapack etc. and have a stack of data and numbers accumulated on dynojets since the 90s way before I ran Honda Challenge to back up my theory and this is why I eagerly support the cap because it levels things out much much easier than changing all of the current rules to remove these aftermarket parts and adjust the weights. It also eliminates the need for more staff like a technical builder or expert to breakdown engines to examine parts and to dyno, which would be very neat to have, but not ideally in the budget aspect for NASA regions. So unless there is a unanimous agreement amongst the racers and the RC and enough data submitted to over rule the cap, the next best thing is to cap the class and limit these issues that are controversial. Thus I hope the cap encourages H4 and H1 to grow with others wanting something different than H2 and this would overall be a growth for all classes which is the true goal here. Quote Link to comment Share on other sites More sharing options...
Leland Posted March 18, 2012 Share Posted March 18, 2012 yep Quote Link to comment Share on other sites More sharing options...
H4CRXSi Posted March 21, 2012 Share Posted March 21, 2012 something else to think about in the H4 to H2 thinking, is that a motor built to the extent of the H4 rules will be illegal when bumping up to H2 as the .040" over allowance for H3-H5 is not allowed for H2. so the idea that said Integra with a B18B1 could just drop 250lbs and race in H2 is not a legitimate option if the motor in H4 trim is built to the limit of the rules. Just something else to think about it. Regards, Sam Quote Link to comment Share on other sites More sharing options...
jmeris Posted March 21, 2012 Share Posted March 21, 2012 @civicek....Dude, I don't know which H4 rules you have or have not read. No way is H2 "basically H4 with a swap". Maybe that is what it was supposed to be way back when and maybe that is how it should be now but H4 does not allow lexan, carbon fiber hood, cams,etc. Some cars in H4 are forced by the rules to race with smaller brake packages than their competitors who have the same motor and weight. Ask me how I know. ok, "dude", besides a swap and a few minor mods, tell me what is the huge difference between them, and again if you read my post I said "basically". You can take a H4 CRX single cam vtec, change the cams and intake and voila you have a H2 car. So BASICALLY is the same car and you didn't even need a swap. That's what I meant by "basically", dude. Dude, I MIGHT be off topic, but: or Sorry dude... Quote Link to comment Share on other sites More sharing options...
Members Marcel D. Posted March 21, 2012 Members Share Posted March 21, 2012 Dude that's funny. Quote Link to comment Share on other sites More sharing options...
realride Posted March 21, 2012 Author Share Posted March 21, 2012 DUDE with a french accent Quote Link to comment Share on other sites More sharing options...
JW Racing Posted March 21, 2012 Share Posted March 21, 2012 Quote Link to comment Share on other sites More sharing options...
RCarroll Posted March 22, 2012 Share Posted March 22, 2012 Dude, I MIGHT be off topic, but: or Sorry dude... That is funny Quote Link to comment Share on other sites More sharing options...
Leland Posted April 2, 2012 Share Posted April 2, 2012 I wonder how your HP caps are going to go lol... and how youre going to go about protesting the winner because he/she obviously cheating right? lol. How were these cap numbers calculated in the first place since Im unable to find the formula? Quote Link to comment Share on other sites More sharing options...
AustinG Posted April 3, 2012 Share Posted April 3, 2012 I wonder how your HP caps are going to go lol... and how youre going to go about protesting the winner because he/she obviously cheating right? lol. How were these cap numbers calculated in the first place since Im unable to find the formula? If you have access to the HC Driver's forum, there's a thread in which these questions are asked. Quote Link to comment Share on other sites More sharing options...
Leland Posted April 3, 2012 Share Posted April 3, 2012 I wonder how your HP caps are going to go lol... and how youre going to go about protesting the winner because he/she obviously cheating right? lol. How were these cap numbers calculated in the first place since Im unable to find the formula? If you have access to the HC Driver's forum, there's a thread in which these questions are asked. not approved guess i still have 1 and 3/4 yrs more to go. i guess in all, i and a couple others are just a little discouraged from traveling to socal now with them adopting the national cap rule which seems a little funky due to, at the moment, i personally am unable to view the driver forum showing the reasoning behind it. Ill start with what comes to my mind when Honda Challenge is mentioned HPD right? Whats the "D" stand for? Lucky or not to know me I couldnt tell you, but can say i have no problem voicing my opinion and normally i can gather enough facts to express that opinion with a lot of BS but at least a little knowledge to make the BS sound good. Back to the "D", development. Development to you means what? To me simply put means better, more efficient... a mushroom(what no one has played Mario Bros?). 1up. Shouldnt hinder one for going big(within the rules correct?) and not home because in due time thats exactly what people are going to do or have done. Im going to cut it short there without spilling over into this side skirt BS which air dams, spoilers, and wings are allowed but how dare us go 1 step further. Again Im still waiting to see the details that brought on this crap, I mean cap. Before I quit this post Im going to add that how can or why would you want each region making their own rules within the same series? Doesnt make it very uniform. Quote Link to comment Share on other sites More sharing options...
Leland Posted April 4, 2012 Share Posted April 4, 2012 so here i am cruzing along and boom... popo lights me up. I pull over. Officer: License, registration and proof of insurance. Me: (already had it ready) Here you go sir. Officer: Stay in your vehicle, Ill be back. few minutes go by officer returns Officer: Please step out of the vehicle and put your hands on your head. im a little confused but do so. officer cuffs me sets me down on the curbing. Officer: May we search you vehicle? Me: Sure few more minutes go by while he searches my vehicle and at that moment a K-9 unit pulls up. K-9 gets out walks around, jumps inside my car and hops out. Officer comes back to me, uncuffs me, returns my belongings and hands me a warning. Me: Whats this for? Officer: A warning for going 1mph over the speed limit. I just stand there for a sec and then Me: Do you race in Honda Challenge, SoCal Honda Challenge? Quote Link to comment Share on other sites More sharing options...
JW Racing Posted April 6, 2012 Share Posted April 6, 2012 Maybe you were "profiled", I know how that feels. Quote Link to comment Share on other sites More sharing options...
joe barile Posted April 14, 2012 Share Posted April 14, 2012 at the moment, i personally am unable to view the driver forum showing the reasoning behind it. If you "log in" you should be able to then view the forum if Jeremy has added you.....good luck Quote Link to comment Share on other sites More sharing options...
Leland Posted April 19, 2012 Share Posted April 19, 2012 at the moment, i personally am unable to view the driver forum showing the reasoning behind it. If you "log in" you should be able to then view the forum if Jeremy has added you.....good luck i can view it so post yourself again or pm the man to see if you can get added... although i can see it i havent had the time to waste to research the reasoning(a beer sounds better everytime) honestly i dont care... jeremy and manny schooled us AZ "Rookies"(we all had less than 4races) at CVR and to expect anything less would be idiotic. cant wait until next chuckwalla event! AZ event no HP caps!!!! bring it!!! Quote Link to comment Share on other sites More sharing options...
National Staff Jeremy C. Posted May 1, 2012 National Staff Share Posted May 1, 2012 at the moment, i personally am unable to view the driver forum showing the reasoning behind it. You are on the list Joe, so you should have access. Quote Link to comment Share on other sites More sharing options...
ghettoracer Posted May 18, 2012 Share Posted May 18, 2012 I understand the concept behind the hp caps, and in certain circumstances, I could see it as being beneficial. However, I do not think HC is one of those circumstances. I personally think that the HP caps will serve to increase the amount of money I will spend over the course of the year. When I first built my car (almost 4 years ago), I chose the b16 knowing full well that I would give up torque to the higher displacement motors but be able to make up the gap on the top end. My old, near stock b16 dynoed at 176 whp and made 110 ft/lbs of torque. I gave up near 30 ft/lbs of torque on a b20 but also had a significant horsepower advantage. Restricted to 165 whp (and assuming I don't lose any torque in the process), my hp advantage over that same b20 just shrank to a mere 5. Giving up 30 ft/lbs of torque doesn't seem like a fair trade off for 5 whp. Now I am in a position where I feel the need to develop a completely new engine platform just to stay competitive. If HC was intended to be all about driver skill and budget (and not one's ability to build and develop a car), it should have been made a spec series. There are way too many variables for something like a HP cap to actually have any real effect. Some people are still going to outspend others, people will still have high-dollar race engines, and certain cars will be quicker than others. Racing to me is about who can go the fastest, not who can go the fastest while spending the least amount of money. If budget is an issue, H4 is still offered as a National class. Hopefully I'm not offending anybody -- I just felt the need to voice my opinion due to the fact that I have been dwelling on this issue for some time now. This is all just my .02. Tony Lisa I'm late to the party and just read the SoCal HP cap. I'm with Tony... having a cap is absurd! You already have the mod limitations and if something is really wrong you fix it there, maybe adjust the weights a little bit but not impose a max hp limit. Then engine building skills and the parts selection plays a huge role in dyno output. Not everyone can afford at $1300 custom header but some racers will always have a bigger budget than you. LIVE with it. It isn't illegal to over spend as long as the parts are in compliance with the rules. And I noticed something strange, why is B20B at 160 and B20B1/B20Z1 at 158? 2 whp different? really? The built H2 B20B long block I bought off Mike Lock use to make ~160 whp at BlackTrax. But that is with a crappy header. I imagine with a good header and a re-tune it will likely be above 160 whp... I can also tell you a D16Z6 built to the rule limit of H2 should be above 140 whp as well. Who came up with these whp cap figures?? Quote Link to comment Share on other sites More sharing options...
wic Posted May 18, 2012 Share Posted May 18, 2012 I understand the concept behind the hp caps, and in certain circumstances, I could see it as being beneficial. However, I do not think HC is one of those circumstances. I personally think that the HP caps will serve to increase the amount of money I will spend over the course of the year. When I first built my car (almost 4 years ago), I chose the b16 knowing full well that I would give up torque to the higher displacement motors but be able to make up the gap on the top end. My old, near stock b16 dynoed at 176 whp and made 110 ft/lbs of torque. I gave up near 30 ft/lbs of torque on a b20 but also had a significant horsepower advantage. Restricted to 165 whp (and assuming I don't lose any torque in the process), my hp advantage over that same b20 just shrank to a mere 5. Giving up 30 ft/lbs of torque doesn't seem like a fair trade off for 5 whp. Now I am in a position where I feel the need to develop a completely new engine platform just to stay competitive. If HC was intended to be all about driver skill and budget (and not one's ability to build and develop a car), it should have been made a spec series. There are way too many variables for something like a HP cap to actually have any real effect. Some people are still going to outspend others, people will still have high-dollar race engines, and certain cars will be quicker than others. Racing to me is about who can go the fastest, not who can go the fastest while spending the least amount of money. If budget is an issue, H4 is still offered as a National class. Hopefully I'm not offending anybody -- I just felt the need to voice my opinion due to the fact that I have been dwelling on this issue for some time now. This is all just my .02. Tony Lisa I'm late to the party and just read the SoCal HP cap. I'm with Tony... having a cap is absurd! You already have the mod limitations and if something is really wrong you fix it there, maybe adjust the weights a little bit but not impose a max hp limit. Then engine building skills and the parts selection plays a huge role in dyno output. Not everyone can afford at $1300 custom header but some racers will always have a bigger budget than you. LIVE with it. It isn't illegal to over spend as long as the parts are in compliance with the rules. And I noticed something strange, why is B20B at 160 and B20B1/B20Z1 at 158? 2 whp different? really? The built H2 B20B long block I bought off Mike Lock use to make ~160 whp at BlackTrax. But that is with a crappy header. I imagine with a good header and a re-tune it will likely be above 160 whp... I can also tell you a D16Z6 built to the rule limit of H2 should be above 140 whp as well. Who came up with these whp cap figures?? Are we ever going to see your car in a Nor-cal race? Quote Link to comment Share on other sites More sharing options...
ghettoracer Posted May 18, 2012 Share Posted May 18, 2012 what's the car count? honestly i'm not all that motivated to do H2. if Ron and Donna were running that was my motivation for picking up Mike's motor. but everyone's watching their budget. so am i. my first committed race this year is at the 24 hours of LeMons in late June at BW with a V8 Volvo built by a friend... Quote Link to comment Share on other sites More sharing options...
wic Posted May 18, 2012 Share Posted May 18, 2012 what's the car count? honestly i'm not all that motivated to do H2. if Ron and Donna were running that was my motivation for picking up Mike's motor. but everyone's watching their budget. so am i. my first committed race this year is at the 24 hours of LeMons in late June at BW with a V8 Volvo built by a friend... This weekend: me Meris Paul Garcia Chris Smith? Andrew Tom Lepper Quote Link to comment Share on other sites More sharing options...
