1975 BMW 2002 GT3
This is a 1975 (base 2002) chassis from New Mexico.
Engine –
Eric Kerman M10 2.0L with one hour of break-in (est. 180-200hp)
Schrick 316 degree cam
320i electronic ignition
Dual Weber 45mm DCOE jetted for the motor
Aluminum radiator
Aluminum oil cooler
Accusump
Vintage baffled wet-sump
Transmission –
Rebuilt 320i 5 speed w/Sachs Sport clutch and new aluminum flywheel
Short shift linkage
Differential –
20% LSD 3.90
Suspension -
Ireland Engineering adjustable rear suspension modified for low ride height. Chopped front struts for low ride height including geometry spacers to correct bump steer
New wheel bearings
Rear coil overs
Body –
Fiberglass hood, doors, trunk
Schnitzer style finder flares
Lexan glass throughout
Seam welded
Custom front spoiler (previous owner owns molds and willing to make more)
Fresh PPG paint job (I believe Alpine white)
All graphics are removable
Wheels –
1 set of new WELD 13x9, 13x10 aluminum racing wheels with used Hoosiers
1 set of new steel 13x9 and 13x10 racing wheels
Brakes –
Disk brakes all 4 corners
Vintage aluminum Brembo calipers up front
320i calipers on the rears
Dual Tilton Master Cylinders
Misc –
New Corbeau FX1 Pro racing seat
Vintage MOMO steering wheel
New Fuel Safe aluminum fuel cell
Spares –
Metal hood
Metal doors
Various chrome trims.
1 - open diff that can be welded up
2 - four speed trans (1-close ratio / 1-standard)
1 - M10 block
(have more to list)
The finishing touches needed:
1. Fuel lines run from firewall to fuel pump and to the fuel cell.
2. Needs a battery. I planned on running a full size battery as a "total-loss" system. I do have an alternator but had not mounted it.
3. Wiring:
Brake lights need pressure switch and wiring
Starter switch
Rain lights
Ignition (later electronic ignition of the 320i. The later year 2002's used this system for a hotter spark. (The cam is a 320i cam so that it works with this newer style ignition...it spins the distributor opposite than the old contact point distributors. All of the ignition is there including the coil and control box to the distributor...just needs 12v.
5. Throttle pedal. I have brand new linkage in a box to hook to the dual Webers.
More pics here: http://s901.photobucket.com/albums/ac218/red986s/GT3%20BMW/
Asking $15,000.
Thanks, Mitch (red986s at yahoo dot com)
