1984 Porsche 944 Autox Spec944
Posted (edited)
1984 Porsche 944 Great Autocross car FP class or a good start on a Spec 944 car.
It has the Paragon Products Suspension Package 944 Spec1-Koni which includes
http://www.paragon-products.com/Koni.../944spec-1.htm a $2000 package
Pair of front Koni Shocks adjustable
Pair of rear Koni Shocks adjustable
Front Adjustable Weltmeister 28mm Sway Bar Kit
Rear Adjustable Weltmeister 22mm Sway Bar Kit
Front Coil Over Kit
Rear Solid Weltmeister Torsion Bar Set 27mm
Also added to the 944 is
Camber Plate Set $250
KLA Strut Brace $140
Aluminum Radiator with new electric fan $390
Carbotech Brake Pads $200 new last year
Stainless Steel brake line set $65 Fronts are on the car, rears are not
Harness Bar with Sparco belts $495
It comes with two Sets of Rims
15” Cookie Cutters ($400 rims) with Hoosier Rains
15” Fuchs with Hoosier R45, New in 2011 ($800 Tires), only has 5 Autox events on them, would be great track day tires. on car now
I also have the front bumper and windshield motor to go with but are not on it at this time.
Car only $3650 obo
The car is in Galena, Ohio 43021
As is, where is
Randy sports2racer at
yahoo dot com
Can you provide info on the engine and tranny? What's been done to it and when as well as what it might need.
Thanks Jerry
  • 1 month later...
Thanks Jerry
The engine and transmission is stock. It runs well but my plan was to run it in Spec 944 and I was going to pull engine and go thru it next. I started on the suspension first and it's handling really well. It's a blast to drive. My plans have change, two sons in College now $$! So it's up for sale.
New price on Car $3450
Wow, someone NEEDS to pick this up for 944 Spec .
I agree. If it were in so. Cal area it would be in my driveway already.
