eurocars Posted March 22, 2012 Posted March 22, 2012 Killer Car For Sale $8750 Firm The #24 Alcohol Killer 944 is For Sale This car has numerous victories in NASA GTS1 and 944Cup races It has been converted to 944Spec Ran as a ITS car for 2 races in 2010 MCSCC and then as a EP for 2011 while still set up for SPEC944 I just did not have the time to run it in NASA Motor <9 Hours on Full Rebuild Lindsey Baffle & Pick-up Kit New Rings, New Main & Rod Bearings Complete Reseal Head/Valve R&R – Gellner Engineering Engine Rebuild by Bill Douglas – Steinel’s Autoworks http://www.steinels.com/ Late SS Header Free Flow Exhaust Suspension - new means 9 hours of use Koni Yellow Sport F&R –NEW 350lb Springs – NEW 30mm Torsion Bar – NEW MO30 Sway Bars - NEW Delrin Bushings - NEW Steel Control Arms – NEW NEW Ball Joints Lindsey Racing Camber Plates KLR Strut Brace Car set up done by Accumoto Motorsports http://www.accumoto.com/ the technician worked for Kelly Moss racing when they campaigned 944's in the Firehawk series Brakes NA Brakes Hawk DTC70/60 Pads Transmission / Clutch NA Short 5th Gear, LSD 1 Season on Rebuild + 9 hours Porsches Spring Centered Clutch <9 Hours Porsche OEM Pressure Plate <9 Hours Safety – 2009 PCA & Nasa Logbooks 2010 & 2011 MCSCC Custom Cage, Dual Nascar Bars 5-Point Harness New 2010 New Hans shoulder harness 2011 Window Net, Right Side Net New 2010 Fire Extinguisher Interior Sparco Evo Seat, Convex Mirror, Sparco Steering Wheel 1 set with Hoosiers - only 3 races on them 2011 2 spare wheels Lexan Windshield This is a great car to drive - I have had no issues with it in the 2 years I have owned it . It is a proven front runner in the past in NASA and PCA with many podium finishes -- email for more pictures or videos as well Quote
