MitchSRossi Posted March 26, 2012 Posted March 26, 2012 FOR SALE - $1600.00 / O.B.O. - new in box New Brembo Gran Turismo Brake System REAR - 4 Piston, Disc Size: 313X28mm, 2 Piece Rotor This braking system originates from the racing components, consisting of a ventilated, drilled disc and 4 piston aluminum calipers, a complete set of high performance brake pads, metal braid tubes and high quality small parts. 1. High Performance Friction Material: Aggressive pads that provide the highest level of performance. 2. Cross-Drilled or Slotted Discs: Clears gasses, cleans pads for better "bite". 3. Mounting Brackets and Assembly Hardware: Aircraft quality included and pre-torqued specifications. 4. Stainless Steel Braided Brake Line: DOT/TUV approved. 5. "Floating" Disc Mounting System with Billet Aluminum Hat: 6. Four Piston Cast Aluminum Calipers: Provide maximum braking force without the flex of sliding calipers. Reduce "Unsprung Weight" for better handling and reduces heat-related stress; increases brake performance and pedal feel. Fits: • 1966-1973 Porsche 911S • 1974-1989 Porsche 911 http://www.flickr.com/photos/62441504@N06/sets/72157629711592123 Quote
