ninetyfourintegra Posted April 23, 2012 Share Posted April 23, 2012 I will apologize for the ignorance of the question but I am only just learning about Miatas. Will a complete engine (and/or Engine and transmission) from a 1992 Miata bolt into a 1999 tub? Engine has a Supercharger and megasquirt, so I'm assuming all electronics will/can be accounted for, will it bolt in or is there a conversion kit/mount required? My thinking is that it will, as I see comments about swaps going the other way but see that FlyinMiata has some conversion kits (http://www.flyinmiata.com/index.php?dept=67). Let me know, Thanks Ron Quote Link to comment Share on other sites More sharing options...
ILIKETODRIVE Posted April 24, 2012 Share Posted April 24, 2012 AFAIK it would be like putting a D16Z6 in an Integra. Quote Link to comment Share on other sites More sharing options...
Members Darren D. Posted April 24, 2012 Members Share Posted April 24, 2012 The 1992 Miata had a 1.6L motor. The 1999 had a 1.8L engine. While the motor will technically fit (will bolt up to the transmission and will fit under the hood), you will have other issues, including wiring. Wouldn't recommend attempting this. Also, you posted this in Spec Miata. That swap would not be legal in that class. Quote Link to comment Share on other sites More sharing options...
ninetyfourintegra Posted April 24, 2012 Author Share Posted April 24, 2012 Understood on legality, the car would actually be destined for PT. I figured I would post in SM forum due to knowledge of Miatas of the people looking at this forum. Thanks. Quote Link to comment Share on other sites More sharing options...
jaje Posted April 25, 2012 Share Posted April 25, 2012 Not sure why you'd go down to a 1.6 liter from a 1.8 liter '99 engine that has valve timing enhancement. You'll lose a lot of power in n/a form. You can add superchargers to the 1.8 liter motors as well. Plus the 1.6 is obd 0 and you'd have to convert it to obd 2. Quote Link to comment Share on other sites More sharing options...
