Pattmanj Posted June 14, 2012 Share Posted June 14, 2012 Rookie in AI NE division here. I am currently running a new Ford Racing Super Duty T-5 trans with a .63 fifth gear (old t-5 trans blew at Summit point last year) and a 3.55 8.8 rear now. I am making 308 hp so the FRSD trans isn't maxed, not to mention I just put it in. On long straights I max out 4th gear at 6400rpm and around 127mph. I am looking for more top end speed without sacrificing too much at lower corner entry/exit speeds In your opinion is going to a 3.33 rear going to help enough (running 2nd, 3rd and 4rth gears)or do you think I should investigate replacing the FRSD fifth gear with a .80 fifth in the existing trans or just breakdown and get a complete Tremec which comes with a .80 fifth. If going with the Tremec do I change the rear gearing anyway? Thanks for your thoughts. Quote Link to comment Share on other sites More sharing options...
SNAKBITN Posted June 15, 2012 Share Posted June 15, 2012 Which way is cheaper for you.Tranny gear or ring and pinion. Quote Link to comment Share on other sites More sharing options...
mbuskuhl Posted June 15, 2012 Share Posted June 15, 2012 Have you played around with a gear calculator yet? If you need one, PM me your email address and I will send you 2 different ones in Excel format. Quote Link to comment Share on other sites More sharing options...
Pattmanj Posted June 17, 2012 Author Share Posted June 17, 2012 I haven't investigated costs of tranny gear swap yet, but a ring and pinion set is around $200. Just polling to see which way would work the best. I worked with a few calculators and changing the tranny gear will give me a better top end IF I get it into fifth (rarely, on long straights etc.) but the 3.33 will give me a decent top end in fourth. Quote Link to comment Share on other sites More sharing options...
