350ZNV Posted May 29, 2005 Share Posted May 29, 2005 The event at Buttonwillow June 11th & 12th will be my first with N.A.S.A. I will be runnin in an HPDE class, but I am interested in the TT Classes. If you guys could help me class my car I would appreciate it. Thanks. 2003 Nissan 350Z Track Model Cold Air Intake High Flow Cats Aftermarket Exhaust Aftermarket Intake Plenum Coilover suspension Sway Bars R-Compound tires 235 Front, 255 Rear Quote Link to comment Share on other sites More sharing options...
Neon2dmaX Posted May 29, 2005 Share Posted May 29, 2005 The event at Buttonwillow June 11th & 12th will be my first with N.A.S.A. I will be runnin in an HPDE class, but I am interested in the TT Classes. If you guys could help me class my car I would appreciate it. Thanks. 2003 Nissan 350Z Track Model Cold Air Intake High Flow Cats Aftermarket Exhaust Aftermarket Intake Plenum Coilover suspension Sway Bars R-Compound tires 235 Front, 255 Rear You should probably look at: http://socal.nasa-tt.com/id17.html 350Z Track Model starts in TT-C with +5 point assessment R Compound Tires: +5 points (if same size as original) Cold Air Intake: +1 Intake plenum: ? (may be considered part of "air intake system") Exhauts (cat back?): +1 High flow cats: ? added/changed sway bars: +2 (or maybe +2 each - check with Greg) Coil over: +7 (unless original shock uses, then maybe only +5) You have a minimum of +15 ponts (even if only +1 point for coil over suspension). Thus, it looks like you would be bumped up to TT-B. Unless you have some other changes that you haven't mentioned (e.g. perfformance brake pads or big brake kit; camber plates; strut bars, or?) you probably would not be bumped higher than TTB. Good luck. Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted May 29, 2005 National Staff Share Posted May 29, 2005 Dave is correct. It sounds like your car is in TTB. If you are new to NASA, you will need approval to run in TT. Please e-mail me your detailed driving resume. Thanks. Quote Link to comment Share on other sites More sharing options...
350ZNV Posted May 30, 2005 Author Share Posted May 30, 2005 Thanks guys. Quote Link to comment Share on other sites More sharing options...
